ASA - External Interface / BGP
Answered Question
Mar 1st, 2010
I have attached my network diagram in a pdf.
My ASA is configured with two outside interfaces
One to each ISP.
Each ISP router is getting a default route from provider.
I am currently using HSRP between the two routers on the inside interface on BVI interfaces of the routers.
I have a static default route configured on the ASA for ISP #1 HSRP's address.
I have IBGP running between the two routers.
I have a local weight preference on each router to take its own ISP out.
I want to utilize ISP #2 more and have created a few static default routes out that HSRP address.
Should I do away with one of the outside interfaces on the ASA?
What is the best way to handle the routing on the outside of the ASA?
Correct Answer by Giuseppe Larosa about 6 years 10 months ago
Hello Trippi,
this can be a problem. ASA can perform load balancing towards different next-hops that are out the SAME interface.
The ASA is a FW first, so the outgoing interface is chosen by the FW xlate according to its configuration.
see
>> Load sharing on the adaptive security appliance is  possible only for multiple next-hops available using single egress  interface.  Load sharing cannot share multiple egress interfaces.
http://www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/route_overview.html#wp1095679
I would suggest you to review your design in order to have a single outside interface to reach both  routers
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Fri, 03/05/2010 - 01:31
Hello Trippi,
see
Hope to help
Giuseppe
