Bandwidth Allocation for a specific VPN Tunnel - PIX 525 7.2(1)
bernal.ramirez
I have a PIX with a 10 MB internet connection. This PIX has several L2L VPN Tunnels configured: Tunnel1, Tunnel2...TunnelN. I want to be able guarentee 5Mb of the total 10Mb to a specific VPN Tunnel. Is this possible? I have read the following links, however I believe that the configuration guidelines I'm looking for are a combination of several examples shown here:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008080dfa7.shtml#tab4
https://supportforums.cisco.com/docs/DOC-1230
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a008084de0c.shtml#cqos
The tunnel is being defined by the following commands:
crypto map prdmay 20 match address vpn_1
crypto map prdmay 20 set peer 61.172.142.222
crypto map prdmay 20 set transform-set TS
access-list vpn_1 extended permit ip 10.14.102.0 255.255.255.0 any
access-list vpn_1 extended permit ip 10.14.101.0 255.255.255.0 any
tunnel-group 61.172.142.222 type ipsec-l2l
tunnel-group 61.172.142.222 ipsec-attributes
pre-shared-key *
Is the following what I need to do in order to accomplish what I want:
priority-queue outside
class-map vpn_5Mb
match access-list vpn_1
match tunnel-group 61.172.142.222
policy-map police-priority-policy
class vpn_5Mb
police output 5120000
service-policy police-priority-policy interface outside
Thank you for your help.
Panos Kampanakis
I don't think the ASA will let you match on ACL and tunnel group at the same time.
Just the ACL will do though. The ACL should match local ip addresses (there are usually no-natted for the VPN anyway).
Here is a page with a QoS examples on the ASA for reference https://supportforums.cisco.com/docs/DOC-1230
I hope it helps.
PK
