Basic question on BGP no auto-summary & advertisement
Answered Question
Mar 1st, 2010
Since I have 'no auto-summary' option on under the bgp process, I was expecting to networks such as 10.2.80.0/24 included under the advertisement 'network 10.2.0.0 mask 255.255.0.0'. However, that did not happen. In order to see the network 10.2.80.0/24 advertised on R4 (BGP 200), I had to create a 'network 10.2.80.0 mask 255.255.255.0' under the bgp 100 on R2.
Am missing something here? If 10.2.0.0/16 and no auto-summary is in place, why 10.2.80/24 is not included?
R2
router bgp 100
no synchronization
bgp log-neighbor-changes
network 10.177.206.0 mask 255.255.255.0
neighbor 10.2.47.193 remote-as 200
neighbor 10.2.255.47 remote-as 100
no auto-summary
ip forward-protocol nd
ip http server
no ip http secure-server
control-plane
R2(config)#router bgp 100
R2(config-router)#network 10.2.80.0 mask 255.255.255.0
R2(config-router)#
R2#
*Mar  1 00:43:09.315: %SYS-5-CONFIG_I: Configured from console by console
R2#
R2#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
     4.0.0.0/32 is subnetted, 1 subnets
B       4.4.4.4 [20/0] via 10.2.47.193, 00:18:03
     10.0.0.0/8 is variably subnetted, 4 subnets, 3 masks
O       10.2.80.0/24 [110/2] via 10.177.206.1, 00:23:21, FastEthernet0/0
C       10.2.60.104/30 is directly connected, FastEthernet1/0
C       10.177.206.0/24 is directly connected, FastEthernet0/0
C       10.2.47.192/28 is directly connected, FastEthernet0/1
     192.168.1.0/32 is subnetted, 1 subnets
C       192.168.1.2 is directly connected, Loopback0
R2#
R4#ping 10.2.80.1
Sending 5, 100-byte ICMP Echos to 10.2.80.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
R4#ping 10.2.80.1 <============= After entering the  net 10.2.80.0 mask /24 on R2 and I can see the route advertised on the border router on AS 200:
Success rate is 100 percent (5/5), round-trip min/avg/max = 372/668/1352 ms
R4#show ip route
C       4.4.4.4 is directly connected, Loopback1
     10.0.0.0/24 is subnetted, 4 subnets
C       10.2.47.0 is directly connected, FastEthernet0/1
C       10.2.55.0 is directly connected, FastEthernet0/0
B       10.2.80.0 [20/2] via 10.2.47.204, 00:00:59
B       10.177.206.0 [20/0] via 10.2.47.204, 00:07:26
C       192.168.1.4 is directly connected, Loopback0
R4#
Correct Answer by Jon Marshall about 7 years 3 months ago
Marlon
The reason why I had to include 'network 10.2.80.0 mask 255.255.255.0' is because I must advertise at least one network which is part of the aggregate-address entry, correct?
Exactly. Glad you got it working.
Jon
Overall Rating: 5 (1 ratings)
KARUPPUCHAMY MA... Mon, 03/01/2010 - 21:56
  • Silver, 250 points or more
BGP auto-summary rule says that ,Take a example that you are having network that 10.2.80.0/24 and you want to advertise into BGP with auto-summary,
So you need to advertise this network via network 10.0.0.0 in the bgp process with auto-summary.you cannot adverise 10.2.0.0 mask 255.255.0.0.it will not work.
so your configuration would be (with auto-summary)
R2
router bgp 100
no synchronization
network 10.0.0.0
Now try to ping , it should work.
for more information, have a look into this below URL
https://www.cisco.com/en/US/tech/tk365/technologies_q_and_a_item09186a00800949e8.shtml#five
regards
Karuppu
Jon Marshall Mon, 03/01/2010 - 23:21
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Marlon
It's not included because with the network statement under BGP there must be an exact match in the IGP routing table for it to be advertised. So when you enter 10.2.0.0/16 as a network statement that is exactly what the router looks for in the IGP table. And when it sees 10.2.80.0/24 it does not consider this a match because the subnet mask is different as is the 3rd octet.
Having "no auto-summary" on does not change the above rule.
Jon
news2010a Tue, 03/02/2010 - 07:13
Oh, that is true!
So imagine I have a number of subnets:10.2.30.0/24, 10.2.41.0/24, 10.2.42.0/24, etc.
Then I want to minimize the number of 'network' statements under the 'bgp router' statement.
I have the option to use the 'aggregate-address' to summarize this under the BGP process, correct?
Jon Marshall Tue, 03/02/2010 - 07:16
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
news2010a wrote:
Oh, that is true!
Marlon
Yes you can aggregate or summarise them to an EBGP peer but to summarise the above 3 networks you would need to use -
10.2.30.0 255.255.192.0  which would include 10.2.0.0 -> 10.2.63.255 which is obviously a lot more /24 networks than just those 3.
Jon
news2010a Tue, 03/02/2010 - 07:54
Sorry for my ignorance, but if I want to summarize all networks under 10.2.0.0/16:
I considered possible networks to be advertised to Corporate border router as: 10.2.1.0/24 - 10.2.255.254/24
Then I removed the 'network 10.2.80.0 mask 255.255.255.0' and I did like shown below:
R3#
router bgp 100
no synchronization
aggregate-address 10.2.0.0 255.255.0.0
neighbor 10.2.55.133 remote-as 200
neighbor 10.2.255.15 remote-as 100
no auto-summary
However I go to my test border router R4 and I no longer see 10.2.80.0/24 there anymore. So this aggregate range is not working...
Do you mind to clarify how the aggregate-address should look like if I want to include all networks under 10.2.0.0/16?
Jon Marshall Tue, 03/02/2010 - 08:03
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
R3#
router bgp 100
no synchronization
no auto-summary
Marlon
Couple of things
1) can you modify your config -
router bgp 100
no network 10.2.0.0 mask 255.255.0.0
2) why do you want the specific routes as well as the aggregate address ?
Jon
news2010a Tue, 03/02/2010 - 08:30
That did it.
Now from R4, I noticed that I can reach for example hosts on 10.2.40.0/24, which does not appear on the border router R4 (AS 200) ip route explicitly, but it works now because is learning how to get there via the 10.2.0.0/16 aggregate.
Thanks much!!
     10.0.0.0/8 is variably subnetted, 5 subnets, 2 masks
B       10.2.0.0/16 [20/0] via 10.2.47.204, 00:00:08
C       10.2.47.0/24 is directly connected, FastEthernet0/1
C       10.2.55.0/24 is directly connected, FastEthernet0/0
B       10.2.80.0/24 [20/2] via 10.2.47.204, 00:00:08
B       10.177.206.0/24 [20/0] via 10.2.47.204, 00:05:13
R4#ping 10.2.40.1
Sending 5, 100-byte ICMP Echos to 10.2.40.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 344/564/684 ms
R4#
R4#show ip route 10.2.40.0
Routing entry for 10.2.0.0/16
  Known via "bgp 200", distance 20, metric 0
  Tag 100, type external
  Redistributing via ospf 1
  Advertised by ospf 1 subnets
  Last update from 10.2.47.204 00:04:18 ago
  Routing Descriptor Blocks:
  * 10.2.47.204, from 10.2.47.204, 00:04:18 ago
      Route metric is 0, traffic share count is 1
      AS Hops 1
      Route tag 100
R4#
Correct Answer
Jon Marshall Tue, 03/02/2010 - 08:46
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Marlon
Jon
KARUPPUCHAMY MA... Tue, 03/02/2010 - 07:26
I have the option to use the 'aggregate-address' to summarize this under the BGP process, correct?---  Yes.
We cannot use aggregate-address  to reduce number "network" command  lines under BGP.
When you are doing aggregate-address, there will be one new network segment(aggregated network)  will install into the BGP routing table and it will advertise to other neighbors and rest all the network's will be suppressed.
Need to be caution that when we are doing aggregation, the aggregated address should not clash with another network which we dont want to do aggregation.
for more info,just have a cisco documentation
http://www.ciscosystems.com/en/US/tech/tk365/technologies_tech_note09186a0080094826.shtml
Karuppu
