tracert over vpn
Mar 1st, 2010
    If i have a vpn concentrator setup in the following manner...
Internet
Router
VPN concentrator
Distribution Switch
a) Will i be able to see the vpn concentrator ip when i tracert from the Distribution switch to the router ( assuming no acl's are blocking icmp )
b) If i can, will i see the vpn concentrator's inside ip / outside ip ( assuming both scenario's as tracert from RAW internet and from inside LAN network via UD )
c) Will the conditions pertaining to tracert change once the vpn concentrator establishes a tunnel. ie : Would encrypted traffic see the vpn concentrator in their trace tests.
d) Since a vpn concentrator acts as a layer 3 device, can i run OSPF on it. I have worked on static routing using concentrators but would like some clarity with regard to this.
              Thanking you,
Uzair Syed Naveed
uzair syed naveed Tue, 03/02/2010 - 02:59
I would also like to know if icmp traffic is classified as "interesting traffic" while being sent through a tunnel. ( assuming the icmp traffic is being generated from the pre approved source subnet )
Related Content
