Help with 3800 Series to have pppoe
Answered Question
Mar 2nd, 2010
Hello all, i would like to ask whatsthe confiuration for cisco 3845  router, my set up is DSL Modem> Cisco3845>PC, my internet is  Static but it need to dial a username and password, but i cant seem to  make it work, been doin it for almost 2 weeks now but i still dont get  internet access hope to hear from you soon, im new at configurin this  routers and i dont know if im doing the right codes for it, sorry to  bother you all, have a reat day
Correct Answer by KARUPPUCHAMY MA... about 7 years 1 month ago
You need to change the config register in to 0x2102.the configuration register shows 0x2142. The             router bypasses the startup configuration stored in NVRAM during its boot             sequence. This feature is normally used during a password recovery             procedure.
router(config)#config-register 0x2102
then write the confiig. reload you router.
Karuppu
Can you paste the sh version of your router.susecting the config-register value.
regards
karuppu
Correct Answer by Reza Sharifi about 7 years 1 month ago
When you are at the router save the config by issuing this command
"wr" after that your config is saved and when your reboot the router you don't loose your config any more
Reza
Now, configuration wise everything is ok.Better check with your ISP.
GigabitEthernet0/1         unassigned      YES unset  down                  down
I hope the cable is coming from your modem to router might be not working.befor contact with ISP check that
cable because the interface is down now.
If both your router and modem's are powered on then it should be up
Karuppu
Just have a look of my BOLD LETTERS once again
Have you tried to configure the below lines in your router.
vpdn enable
no vpdn logging
vpdn-group pppoe
  request-dialin
   protocol pppoe
Can you paste the output of the below command
#sh ip int br
Even if you are not able to access internet, contact your ISP.
regards
karuppu
Can you paste the router current running configuration.
DHCP is not necessary to configure,that is used to assign the IP dynamically to your desktops.
regards
karuppu
I have prepared the configuration for your router.
Just do copy paste. for more infor refer that url which i gave in the same post
vpdn enable
no vpdn logging
vpdn-group pppoe
  request-dialin
   protocol pppoe
interface GigabitEthernet0/0
ip address 192.168.10.3 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
duplex auto
speed auto
media-type rj45
int gi0/1
no sh
pppoe-client dial-pool-number 1
interface dialer1
ip address negotiated
mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication chap pap callin
ppp chap hostname
ppp chap password
ppp pap sent-username password
ip nat inside source list 1 interface dialer1 overload
ip route 0.0.0.0 0.0.0.0 interface dialer 1
access-list 1 permit 192.168.10.0  0.0.0.255
Karuppu
I have changed the interface config (bold).Hope it will clear your doubt
vpdn enable
no vpdn logging
vpdn-group pppoe
  request-dialin
   protocol pppoe
ip nat inside
duplex auto
speed auto
media-type rj45
int gi0/1
no sh
interface dialer1
mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
ppp chap hostname
ppp chap password
Karuppu
As per your configuration you have one E1 controller card and 2 Giga interfaces in your router.
Can you tell me about your internet connection. ??  -- If yes then connect your internet link into one of the gigabitethernet port and configure that interface as ppoe interface.
Is the internetconnection via  ethernet connection or connected via any modem ??  --
Karuppu
Instead of ATM , you have to use your current interface which is going to connect your ISP from your router and configure ppoe in that interface.
regards
karuppu
Glad to help you.Once you got success in the configuration update your status in the post.
Karuppu
Nothing to worry.
Find the url which will help you to configure PPoE in cisco router.
In the below example use your ethernet interface instead of ATM
Cisco DSL Router Acting as a PPPoE Client with a Dynamic IP Address
http://www.cisco.com/en/US/tech/tk175/tk15/technologies_configuration_example09186a008071a6c3.shtml
Cisco DSL Router Acting as a PPPoE Client with a Static IP Address
http://www.cisco.com/en/US/tech/tk175/tk15/technologies_configuration_example09186a008071a799.shtml
Hope it will helps u to configure PPoE in cisco 3845 router.
regards
karuppu
Overall Rating: 5 (14 ratings)
paolo bevilacqua Tue, 03/02/2010 - 03:31
  • Hall of Fame,
    Founding Member
Recommend you engage someone experienced.
if he still has trouble can come back here at any time.
nekaratal Wed, 03/03/2010 - 22:18
Hello, good day, im still havin trouble with my cisco3845, i cant have internet access, i tried to have my friend help me but still wont work, can you help me please, i dont know anyone who is more expirience with the device, hope im not bothering you, have a great day many thanks
Correct Answer
KARUPPUCHAMY MA... Wed, 03/03/2010 - 22:26
  • Silver, 250 points or more
Nothing to worry.
regards
karuppu
nekaratal Wed, 03/03/2010 - 22:33
Thank you very much i will try to configure the Router now, thank you thank you, hope im not bothring you, have a great day and thanks alot again
Correct Answer
KARUPPUCHAMY MA... Wed, 03/03/2010 - 22:35
Karuppu
nekaratal Wed, 03/03/2010 - 22:45
some commands are not reconize by cisco3845   like the atm comand, is there any substitute?
Correct Answer
KARUPPUCHAMY MA... Wed, 03/03/2010 - 22:47
regards
karuppu
nekaratal Wed, 03/03/2010 - 22:49
i will try which one, i dont have any idea what to use i just new at configuring this routers hope im not bothering you thanks again
KARUPPUCHAMY MA... Wed, 03/03/2010 - 22:52
No problem. See In which interface you have terminated your internet(DSL) link to your router.It should be either your ethernet interface or your serial interface.
can you paste the sh running-configuration and sh interface of your router
regards
karuppu
nekaratal Wed, 03/03/2010 - 22:58
This is the sh interface
GigabitEthernet0/0 is down, line protocol is down
  Hardware is BCM1125 Internal MAC, address is 001e.f7ae.6ec0 (bia 001e.f7ae.6ec
0)
  Internet address is 192.168.10.3/24
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Unknown duplex, Unknown Speed, media type is RJ45
  output flow-control is XON, input flow-control is XON
  Last input never, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
     2 output errors, 0 collisions, 1 interface resets
     2 lost carrier, 0 no carrier, 0 pause output
GigabitEthernet0/1 is administratively down, line protocol is down
  Hardware is BCM1125 Internal MAC, address is 001e.f7ae.6ec1 (bia 001e.f7ae.6ec
1)
  MTU 1492 bytes, BW 1000000 Kbit, DLY 10 usec,
     1 output errors, 0 collisions, 0 interface resets
     1 lost carrier, 0 no carrier, 0 pause output
Service-Engine1/0 is administratively down, line protocol is down
  Hardware is I82559FE, address is 001e.f7ae.6ed0 (bia 001e.f7ae.6ed0)
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Last input 00:00:03, output 00:00:03, output hang never
323 packets input, 124171 bytes, 0 no buffer
     Received 110 broadcasts, 0 runts, 0 giants, 0 throttles
     325 packets output, 134628 bytes, 0 underruns
     0 lost carrier, 0 no carrier
NVI0 is up, line protocol is up
  Hardware is NVI
  Interface is unnumbered. Using address of NVI0 (0.0.0.0)
  MTU 1514 bytes, BW 10000000 Kbit, DLY 0 usec,
  Encapsulation UNKNOWN, loopback not set
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
And this is the running config
Current configuration : 1025 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
resource policy
no network-clock-participate wic 3
ip cef
vpdn enable
voice-card 0
no dspfarm
!controller E1 0/3/0
ip nat inside
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
mtu 1492
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface Service-Engine1/0
no ip address
shutdown
ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line 66
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
login
scheduler allocate 20000 1000
end
Correct Answer
KARUPPUCHAMY MA... Wed, 03/03/2010 - 23:47
Karuppu
nekaratal Wed, 03/03/2010 - 23:55
My internet connection is a DSL connection, im using a modem, that is directly connected to my cisco3845 which is gigaethernet 0/1 then the other giga ethernet 0/0 is connected to my pc. DSL MODEM>CISCO3845>PC
Correct Answer
KARUPPUCHAMY MA... Thu, 03/04/2010 - 01:01
vpdn enable
no vpdn logging
vpdn-group pppoe
  request-dialin
   protocol pppoe
ip nat inside
duplex auto
speed auto
media-type rj45
int gi0/1
no sh
interface dialer1
mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
ppp chap hostname
ppp chap password
Karuppu
nekaratal Thu, 03/04/2010 - 01:14
hello, thank you very much, really appreciate it, btw how do i configure the giga0/1 what confiuration would i put in it? so it would connect to my pc
sorry to bother you
Correct Answer
KARUPPUCHAMY MA... Thu, 03/04/2010 - 01:19
vpdn enable
no vpdn logging
vpdn-group pppoe
  request-dialin
   protocol pppoe
ip nat inside
duplex auto
speed auto
media-type rj45
int gi0/1
no sh
interface dialer1
mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
ppp chap hostname
ppp chap password
Karuppu
nekaratal Thu, 03/04/2010 - 01:23
thanks you very much sir really appreciate it, sorry to bother you, goin to try it now ty ty, have a great day
nekaratal Thu, 03/04/2010 - 16:26
Hello again sir, the configuration is not workin do i need to put an ip dhcp pool? but i dont know how. sorry to bother you again, hope you have a great day
Correct Answer
KARUPPUCHAMY MA... Thu, 03/04/2010 - 17:23
regards
karuppu
nekaratal Thu, 03/04/2010 - 17:42
hello sir good day, this is the confiuration of my cisco3845
Current configuration : 1419 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip cef
vpdn enable
voice-card 0
no dspfarm
controller E1 0/3/0
ip nat inside
duplex auto
speed auto
media-type rj45
no ip address
duplex auto
speed auto
media-type rj45
pppoe enable
no ip address
shutdown
interface Dialer1
mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
ppp chap hostname 27061455
ppp chap password 0 196581626
ppp pap sent-username 27061455 password 0 196581626
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
ip nat inside source list 1 interface Dialer1 overload
control-plane
line con 0
line aux 0
line 66
no exec
transport input all
line vty 0 4
login
end
Correct Answer
KARUPPUCHAMY MA... Thu, 03/04/2010 - 17:50
vpdn enable
no vpdn logging
vpdn-group pppoe
  request-dialin
   protocol pppoe
#sh ip int br
regards
karuppu
nekaratal Thu, 03/04/2010 - 17:53
yes i tripe to put the command
vpdn enable
no vpdn logging
vpdn-group pppoe
  request-dialin
   protocol pppoe
but the last line is not available its just l2tp but still i put the protocol pppoe
this is the sh ip int brief
Interface                  IP-Address      OK? Method Status                Prot
ocol
GigabitEthernet0/0         192.168.10.3    YES manual down                  down
Service-Engine1/0          unassigned      YES unset  administratively down down
NVI0                       unassigned      NO  unset  up                    up
Dialer1                    unassigned      YES manual up                    up
Correct Answer
KARUPPUCHAMY MA... Thu, 03/04/2010 - 18:17
Karuppu
nekaratal Thu, 03/04/2010 - 18:20
hello, so my configuration is correct? the cable to use it straight = DSL modem > cisco 3845 then cross over cable from cisco 3845 to PC right?
nekaratal Thu, 03/04/2010 - 18:55
hello sir i tried to put the utp cables to the modem and my pc they are both up, but still i have limited sonnectivity i dont know what seems to be the problem, sorry to bother you sir
nekaratal Fri, 03/05/2010 - 18:47
can i ask a question again, whats the command for the router so it will load its start up config when ever i turn it off? i keep on copyng the start up to runnn everytime i turn it off.
Correct Answer
Reza Sharifi Fri, 03/05/2010 - 18:57
  • Cisco Designated VIP,
    2017 LAN
Reza
nekaratal Fri, 03/05/2010 - 19:09
wont work what  mean is every time i restart the router the runnng config is set on default so i have to load the start up config aain so it will be in runnin, is there any option that it will auto load the start up config every time it is turn on
Correct Answer
KARUPPUCHAMY MA... Fri, 03/05/2010 - 19:34
regards
karuppu
nekaratal Fri, 03/05/2010 - 19:45
Cisco 3845 (revision 1.0) with 225280K/36864K bytes of memory.
Processor board ID FHK1209F19G
2 Gigabit Ethernet interfaces
1 terminal line
1 Channelized E1/PRI port
1 cisco service engine(s)
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
62720K bytes of ATA System CompactFlash (Read/Write)
Configuration register is 0x2142
Correct Answer
KARUPPUCHAMY MA... Fri, 03/05/2010 - 19:48
Karuppu
nekaratal Fri, 03/05/2010 - 19:52
its ok now thanks alot have a great day sir many thanks agan
