TCP to X.25 Translation
Mar 2nd, 2010
  Request for help on the configuration to convert an IP traffic to x.25 host.
I am using the following router config with the error logs below. Connection failed without any reason. Anyone has done this could share tips with me on how to get it right. thanks.
interface Serial0/1/1
description To AE testing PW743022
no ip address
encapsulation x25 dce ietf
x25 address 13133
x25 map rbp 0200000 local port 4005
2w3d: X25 RBP: Incoming connection for port 4005 from 192.168.0.100 port 4897
2w3d: Serial0/1/1: X.25 O R1 Call (11) 8 lci 3
2w3d:   From (5): 13133 To (7): 0200000
2w3d: x25rbp_tcp_disconnect_ind: closing session 44B6A9BC, handle 44BAADF0, states 3 0 0
2w3d: X25 RBP: TCP connection closed
paolo bevilacqua Tue, 03/02/2010 - 03:28
  • Hall of Fame,
    Founding Member
Trace seems incomplete and missing proper timestamps.
You may also find that TCP host is closing connection, take an ethernet trace.
