Cisco Smart Install, opens up TCP port 4786, want it disabled
Answered Question
Mar 2nd, 2010
Hello, I have upgraded a couple of 2960G switches to 12.2.52SE and now discovered that TCP port 4786 is open on the switches.
I have looked in the document http://www.cisco.com/en/US/docs/switches/lan/smart_install/release_12.2_52_se/configuration/guide/smart_install.html trying to find a way to disable this function/port, but didnt find anything usefull.
Have anyone found a way to disable this function/port?
BR /Christian
Correct Answer by Kevin Morales about 3 years 11 months ago
Hello, In version  15.0(2)SE2 aplly this command:
config t
no vstack
Sw01#sh vstack config
Role: Client (SmartInstall disabled)
Vstack Director IP address: 0.0.0.0
*** Following configurations will be effective only on director ***
Vstack default management vlan: 1
Vstack start-up management vlan: 1
Vstack management Vlans: none
Join Window Details:
         Window: Open (default)
         Operation Mode: auto (default)
Vstack Backup Details:
         Mode: On (default)
         Repository:
Overall Rating: 4.7 (3 ratings)
Ganesh Hariharan Tue, 03/02/2010 - 02:54
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
BR /Christian
Hi BR,
As per the IANA the following TCP port 4786 is reserved for Smart Install Service,check out the below link for more information.
http://www.iana.org/assignments/port-numbers
Hope to Help !!
Ganesh.H
ankugarg Thu, 06/09/2011 - 08:04
  • Bronze, 100 points or more
Starting with IOS version.12.2(58)SE,there is a way to close port 4786.See the latest docs for more details.
Ankur
Correct Answer
Kevin Morales Wed, 05/01/2013 - 18:07
config t
no vstack
         Mode: On (default)
         Repository:
