Ganesh Hariharan Tue, 03/02/2010 - 03:51
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hello Dear's
There are many unwanted incidents generating in my MARS, how can i customized to important's only and to avoid unwanted ones.
Check ou the below link on MARS rule configuration hope that helps.
http://www.sans.org/reading_room/whitepapers/logging/configuring_and_tuning_cisco_csmars_2044
Remember to rate the helpful post
Ganesh.H
thomasandy32 Tue, 03/02/2010 - 04:41
Thanks ganesh,
There are plenty of rules in MARS to trigger the incident,If i deactivate those i wont get any incident from that rule,but what are the most typical one's which are always kept active in view of attack's and service unavailability.
I have not worked on MARS ,i will be going to install soon,making things clear before implementation.
Ganesh Hariharan Fri, 03/05/2010 - 07:00
Thanks ganesh,
Hi Thomas,
Check out the below link hope that helps
Ganesh.H
chris.cumbaa Mon, 03/15/2010 - 09:31
There's a "False Positive Tuning" link to the right of each incident.  You will need to review the data provided in the incident to decide if the information is relative to an attack.  The false positives, based on your discretion, can be logged but not alerted, or completely dropped.  You can configure false positives based on port information, IP, time/date, reporting device, etc.
