callmanager upgrade fails
Answered Question
Mar 2nd, 2010
guys have a cm ver 6.1(1) which wont upgrade, have tried to upgrade to a few diff vers, anyone ever seen this type of error before
Correct Answer by Aaron Harrison about 6 years 10 months ago
Good to hear it's sorted out.
Thanks for the rating, BTW ;-)
Aaron
Correct Answer by David Hailey about 6 years 10 months ago
Let's back this up if you don't mind.  You say you have 6.1.1 - so first things first, what version(s) have you tried to upgrade to?  Did you experience this error on the very first attempt?  If so, what was the upgrade path?
How was this system built?  Was this a 4x to 6x upgrade build or was this a fresh 6x build?  Alternately (it could be 5x to 6x).  Give me some details and we'll try to walk this out.
Hailey
Please rate helpful posts!
Overall Rating: 5 (2 ratings)
Aaron Harrison Wed, 03/03/2010 - 08:13
Looks like the failure may be time zone related - perhaps try setting your time zone to a different/equivalent one, or back to GMT temporarily whilst you upgrade?
Failing that you would need to collect full logs from RTMT - do a collect files, and grab the Install /Upgrade traces, and DB Installation service traces. Do this once for the 'active' partition, and again for the 'inactive' partition.
Aaron
mark.carroll Thu, 03/04/2010 - 01:38
hi
thanks, tried that but ti comes back with the same error just different time zone, I changed to GMT so its replaced Eire with GMT but error the same
Aaron Harrison Thu, 03/04/2010 - 01:55
OK - so that's the only error I can see on that little screen grab.
You need to do it the hard way (retrieve the logs as described, and analyse them) or raise a case with TAC.
As you've tried different versions, either all Cisco's software is broken, or you have something in your config DB that all of them don't like.
Aaron
Please rate helpful posts...
Correct Answer
David Hailey Wed, 03/10/2010 - 17:38
Hailey
Correct Answer
Aaron Harrison Thu, 03/11/2010 - 04:27
Aaron
