WAAS optimization problem
Hi Mr./Mrs.,
I have a demo for WAEs, two WAEs in the Head Office, (WAE512-k9) one as a Central Manager, and the othe is Core WAE.
One WAE-NM in the Branch, but connected on Router, then this router connected to the WAN router.
the gateway of the WAE-NM is the ip address of the integrated service interface, the router that is configured in the router list is the ip address of the LAN of WAN router, WCCP configuration on the WAN router not in the router that has the WAE-NM, services 61,62 are configured on the WAN interface, and wccp excluded is configured on the LAN interface of the router (the connetion between  the two routers).
There are alot of sessions are appeared on the WAEs connection statistics, but all of them has Policy Applied  (None).
Ganesh Hariharan
Hi Mr./Mrs.,
Check out the below links how to apply policy in WAAS hope that helps
http://www.ciscosystems.ch/en/US/docs/app_ntwk_services/waas/waas/v407/configuration/guide/policy.html#wpxref64690
http://www.ciscosystems.ch/en/US/docs/app_ntwk_services/waas/waas/v407/configuration/guide/apx_apps.html#wpxref87691
Remember to rate the helpful post
Ganesh.H
HI Ganesh,
Thanks for your highly response.
For example, I tried the remote desktop application, I have already default policy for the remote desktop (port 3389) that is called (MS-Terminal-Services) which has TFO only as the acction applied, but when I see the monitored traffic, I see it with application policy (None).
I tried to change from TFO only to Full Optimization, but the same behviour, the session appears in the connection statistics with (None) policy applied.
Best Regards
Amr Abd El Mohsen
HI Ganesh,
Best Regards
Amr Abd El Mohsen
Hi Ganesh,
Best Regards
Amr Abd El Mohsen
Best Regards
Eng. Amr Abd El Mohsen
Technical Support Engineer
(Routing & Switching Team)
Systems Engineering of Egypt
Mobile : +2 016 5514446
Tel (Direct) : +202 22921117
Operator : +202 22921100
Secretary : +202 22921136
Fax : +202 22901673
e-mail : amr_abdelmohsen@seegypt.com
