LMS 2.6 - DFM - Disable Alerting on Duplicate IP
Answered Question
Mar 2nd, 2010
I'm trying to clean up some of the false positives in DFM and have eliminated most of the ones I've seen by simply unmanaging interfaces or ports, but there is one alert that I can't seem to find a good way to get rid of. We have a few sites that have two 2811 routers at them for redundancy. These routers are configured to look exactly the same as far as interfaces and IPs go, minus a management interface and cross-connect, which of course would have to be different in order to manage the devices. For all other interfaces, the routers have the same IPs configured in a 1 to 1 mirror situation. The problem this poses, is that DFM sees these duplicate IPs and alerts on them. This is a fantastic feature, but for this situation, I would like to eliminate the duplicate IP alert for these routers only.
I've been looking at customizing notifications, but I can't seem to find where I can actually remove the alert from DFM. I've unmanaged all of the interfaces that are configured with these addresses, but it doesn't seem to make the error go away. I'm guessing it's picking these up when polling the Loopback0 interface, and then alerting on them.
Is there a way for me to remove the Duplicate IP alert for just these routers? I'm sure there is a simple answer I'm over looking, but if any of you know, I would greatly appreciate it. Thanks!
Correct Answer by Joe Clarke about 7 years 3 weeks ago
No, you cannot do that. The duplicate IP event is not one that is customizable.  DFM currently does not understand L3 redundancy, and thus throws these false positive duplicate errors.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Tue, 03/02/2010 - 12:06
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
tadams7541 Wed, 03/03/2010 - 04:41
Thanks for the reply! I guess I'll just mark those alerts as acknowledged and disregard them.
Martin Ermel Wed, 03/03/2010 - 05:10
  • Blue, 1500 points or more
What does this mean exactly ? "DFM currently does not understand L3 redundancy...."
Are they working on a change of this (mis-)behaviour?
Related Content
