Bandwidth Problem
Answered Question
Mar 2nd, 2010
Dear all,
i m having two links one is Multilink(4Mbps)& Pos-Stm(155Mbps)
i get the following output , but when i made Multilink up,  * 172.26.44.38
is replaced with  10.72.1.218(MultiLinkIp)
whatz the command i can give so that default it will go through POS
ROUTER# sh ip route 10.193.215.0
Routing entry for 10.193.215.0/24
  Known via "bgp 65204", distance 20, metric 0
  Tag 9829, type external
  Redistributing via ospf 100
  Advertised by ospf 100 subnets
  Last update from 172.26.44.38 7w0d ago
  Routing Descriptor Blocks:
  * 172.26.44.38, from 172.26.44.38, 7w0d ago
      Route metric is 0, traffic share count is 1
      AS Hops 2
      Route tag 9829
Correct Answer by Giuseppe Larosa about 7 years 1 month ago
Hello Anand,
the IP prefix is learned on an eBGP session (AD=20) with an AS path containing two AS numbers
under router bgp process
router bgp 65204
neigh 172.26.44.38 weight 45000
can make the trick
to be sure what to do we should see sh ip route 10.193.215.0 and sh ip bgp 10.193.215.0 when the multilink is up
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Tue, 03/02/2010 - 05:32
  • Hall of Fame,
    Founding Member
Hello Anand,
router bgp 65204
can make the trick
Hope to help
Giuseppe
