IPCC extension not transferring
Answered Question
Mar 2nd, 2010
Dear all.
I design one script for cisco IPCC. my design is like that. Welcome to ABC company, press 1 for english and press 2 for arbic. now take the example of english menu, once i press 1 recording comes ( If you know the extension number dial it now or press 1 for A dep press 2 for B dep press 3 for C dep and press 4 for D dep. all other extensons that not start .. 1, 2 , 3 ,4 is trasferring fine. but when i try to trasfering on let say extension 412 its not trasfering and repeat my menu.
Please help me in this how i solve my problem.
I am also attaching my script for more clarification.
Best regards,
Fahad
Correct Answer by Gabriel Saavedra about 7 years 3 months ago
Hi this is because when you dial and extension that starts with 1 2 3 or 4 it goes to the unsuccesfull step, I will try as a workaround here to use the first get digit string with input lenght 4 so when you dial any extension it will be in the succesfull step and then you can use there the "go to dialing". If the person dials only 1 or 2 or 3 or 4 then the call will go to the time out step so there you can make the switch or and if step to tell "if the sdigit is 1 set extnXfer=421" and use the "go to dialing"
Gabriel.
Overall Rating: 5 (1 ratings)
Correct Answer
Gabriel Saavedra Tue, 03/02/2010 - 07:27
  • Silver, 250 points or more
Gabriel.
fahadqureshi Thu, 03/04/2010 - 00:37
Dear Sir,
Thank you so much for your kind reply. Sir i tried to workaround on that. but still i am not able to understand where i put exact get commnad because i am new to ipcc. If possible can you please edit my script and send back to me. I will be very thank full to you.
Waiting for your kind reply
Best regards,
Fahad
fahadqureshi Thu, 03/04/2010 - 05:49
Dear Sir,
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
I successfully put the get command before my menu get command and its working fine and also transferring to 4xx ext. but now the issue is if I try to dial any of the menu option like ..1 ,2 ,3,4 so its switch to next get command and again wait for input digit.
For example:
1.       Welcome to ABC company press 1 for Arabic press 2 for English
I press 2 . den recording comes.
If you know the extension number dial it now or press 1 for A dep press 2 for B dep press 3 for C dep and Press 4 for D dep.
( if I dial the any of the extension it is going fine but if I dial any of the options like 1 ,2 ,3 ,4 so it is not traferring until I press again the 1,2,3,4 any of the option.
Please find the attached modified Script.
Please guide me sir how I move furhter
