VTI , failed to encrypt second tunnel
Mar 2nd, 2010
Good day . I am connecting two remote sites over  two VTIs protected with ipsec. Both tunnels are up and running and i can ping both inside ends. Everything works fine when i apply ipsec protection on one of the tunnels , but after applying protection to the second tunnel i recieve this:
insert map into mapdb AVL failed : map + ace pair already exists on mapdb.
