QoS Issue/Help Needed
Mar 2nd, 2010
Hi All, really need some help here... Long running issue with an MGCP gateway connected to a QoS enabled ADSL circuit. The circuit runs at 2048K down and 256K up. Now the QoS profile which is applied to a ppp dialer is as follows:
class-map match-any Voice-Input-Class
match ip precedence 5
match ip dscp ef
match protocol skinny
policy-map Tiscali-VoIP-LLQ-Out
class Voice-Input-Class
priority 200
set ip precedence 5
class class-default
My first question is, wouldn't having a 200K strict priority queue like this purely for voice and signalling (i know not best practice) on a circuit with a maximum upstream bw of 256K completely starve out any other traffic heading upstream on this circuit?
Second, shouldn’t i see packets matched in the strict priority queue below? I do see them being remarked...
[REMOVED]#show policy-map interface dialer 1
Service-policy output: Tiscali-VoIP-LLQ-Out
Class-map: Voice-Input-Class (match-any)
5942646 packets, 363944143 bytes
30 second offered rate 41000 bps, drop rate 0 bps
Match: ip precedence 5
3616891 packets, 238718354 bytes
30 second rate 41000 bps
Match: ip dscp ef (46)
0 packets, 0 bytes
30 second rate 0 bps
Match: protocol skinny
2325755 packets, 125225789 bytes
Strict Priority
Output Queue: Conversation 264
Bandwidth 200 (kbps) Burst 5000 (Bytes)
(pkts matched/bytes matched) 0/0
(total drops/bytes drops) 0/0
QoS Set
precedence 5
Packets marked 5938941
Class-map: class-default (match-any)
11204238 packets, 1756554359 bytes
30 second offered rate 18000 bps, drop rate 0 bps
Match: any
[REMOVED]#show policy-map interface virtual-access2
Third, since the virtual-access interface is the actual queuing interface shouldn’t i see the service policy cloned to this interface?
Sorry, i know, three questions for the price of one but anyway, if anyone can help because TAC don’t seem to be able to i would really really appreciate it!
