03-02-2010 09:07 AM
I'm looking to upgrade a ft pair of ACE modules to a more recent software release, from A2(1.4), but was wondering if there is a recommended upgrade path or version that is viewed as more stable than another. I believe A2(2.3) was released after A2(3.0) and I'm aware that the 'latest' version number is not always the best so any advice or personal experience would be gratefully received, i.e. would there be any reason to only upgrade to A2(1.6a) and no higher or does A2(2.3) include A2(1.6a) bug fixes as well as the new features?
thanks in advance
Matthew
Solved! Go to Solution.
03-02-2010 10:44 AM
Hi Matthew,
The A2(2.3) release has all the fixes that A2(1.6a) has, and then some. If you are looking only for stability, then I would recommend A2(2.3) for now. Not that A2(3.0) has proven to be unstable, but I would only go to that if you want or need one or more of the new features added to that release. A2(1.6a) will be the last release of the A2(1.x) release train.
Hope this helps,
Sean
03-02-2010 10:44 AM
Hi Matthew,
Hope this helps,
Sean
03-03-2010 05:20 AM
Cheers Sean, appreciated.
Matthew
01-20-2011 06:55 PM
What is the latest recommended path for production environments for an ACE10 module? (A2(1.6a) to the A2(2.x) train or is the A2(3.x) train ok to use as well?)
The module is in a cat running 12.2(33)SXH2a.
Cameron
