CCME phone config problem
Mar 2nd, 2010
I am having trouble configuring receptionist phones. Both are 7961 with 7914 side cars, I want both phones to ring simultaneously. So if a call comes in on the extension associated with ephone-dn 12 both phones ring on button 1.
Right now it works unless ephone 20 is off hook, then ephone 19 does not ring or display the additional call
ephone  19
device-security-mode none
mac-address 001E.7AC4.A2B8
type 7961 addon 1 7914
button  1o12,22 2o6,26 3o7,27 4m14
button  5m11 6m13 7m21 8m17
button  9m18 10m20 11m19 12m15
button  13m16 14m3 15m23 16m24
button  17m25 18m10
ephone  20
mac-address 001E.7AC5.5D51
username "NKujawa" password 0000
button  1:12 2:6 3:7 4m14
button  17m25 18m10
paolo bevilacqua Tue, 03/02/2010 - 12:42
  • Hall of Fame,
    Founding Member
You basically have two choices:
Upgrade to IOS 12.4(22)YB5 or newer, use octo-line DN, that will behave as you desire.
or
Configure multiple DNs with the same number, huntstop channel, place them in overlay (o or c separator) on button.
I would recommend the first.
