Spanning-tree question on a pair of 6509 and HP BL p-class GbE2 Interconnect Switch
Mar 2nd, 2010
We have 2 core 6509 switches core1 and core2 that connected to each other over a port-channel1 made up of 6 ports (5/1-5/6). All Vlans are allowed on this etherchannel.
We also have a HP Interconnect switch connected to core1 and core2 on port 8/1 core1 and port 8/1 core2.  For some reason all the network traffic is going from core1 to HP switch first and then go over to core2 via port 8/1.  That how our traffic is going across the cores right now.  We would like to have our network traffic going across the cores through the etherchannel.
6509 core1
vtp domain FP_VTP
vtp mode transparent
interface port-channel1
switchport
switchport trunk encap dot1q
switchport trunk native vlan 999
switchport trunk allowed vlan 1,100-107,999
switchport mode trunk
no ip address
When we do show spanning-tree root, Vlan0001 is going to root port gi8/1 which connected to HP switch.
What would be the best way to configure the 6509s to use etherchannel instead of gi8/1 between core1 and core2?
-Smith-
Jon Marshall Tue, 03/02/2010 - 12:20
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
-Smith-
Have you configured the 6500 switches to be the STP root and secondary for all the vlans. If youy haven't then the HP switches could be selected as root and secondary.
If you haven't you need to configure them but you will need an outage because there will be an STP recalculation.
Jon
contech-nelsong Tue, 03/02/2010 - 12:22
Do you have one of the 6509s configured as root?
spanning-tree vlan root primary sets the device to the recommended root bridge settings
spanning-tree vlan root secondary can be used on another device to make that the backup root bridge
ssamaharn Tue, 03/02/2010 - 12:53
Thank you very much for a quick reply.  How do I check on the core to see if I have the first core STP root for all vlans?  I'm pretty sure I dont have that setup for sure.
-Smith-
contech-nelsong Tue, 03/02/2010 - 12:58
on the device you want to be root:
sh spanning-tree vlan
see if the reported Root ID and Bridge ID match.
The Bridge ID is what that device thinks it is, and the Root ID is what it thinks the root bridge's ID is.
Jon Marshall Tue, 03/02/2010 - 12:58
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Pick a vlan and do "sh spanning-tree vlan " and post output.
Also there would be lines in your config on the 6500 switches along the lines of
or
spanning-tree vlan priority
Jon
ssamaharn Tue, 03/02/2010 - 13:28
show spanning-tree vlan 1
vlan0001
spanning tree enabled protocol ieee
Root ID Priority 32768
Address 0002.a5d1.275b
Cost 4
Port  897 (GigabitEthernet 8/1)
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 32769 (priority 32768 sys-id-ext 1)
Address 0019.07b5.6400
Aging Time 300
contech-nelsong Tue, 03/02/2010 - 13:32
that device is not the root bridge.
the root bridge is one of the HP devices (0002.a5 is an HP MAC address), probably by virtue of its lower MAC address.
Set the device to be root and you should see the traffic passing correctly
Jon Marshall Tue, 03/02/2010 - 13:34
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
vlan0001
Cost 4
Aging Time 300
From the above -
the above is the root bridge. From the mac-address 0002.a5 is HP.
this is mac-address of the 6500.
When you are on the root switch the 2 mac-addresses will match.
Jon
ssamaharn Wed, 03/03/2010 - 13:11
I've been reading about portfast BPDU guard.  What would be the best practice for two 6509s to talk to each over an etherchannel?
I have the show spanning-tree root, show spanning-tree summary and show config on one of the core 6509s.
vlan                         Root ID               Root   Hello Max Fwd     Root Port
________________________________Cost_______________________
vlan0001     32768     0002.a5d1.275b     4     2     20     15     gi8/1
vlan0100     32686     0019.07b5.6400     0     2     20     15
vlan0101     32869     0019.07b5.6400     0     2     20     15
vlan0102     32870     0019.07b5.6400     0     2     20     15
vlan0103     32871     0019.07b5.6400     0     2     20     15
vlan0104     32872     0019.07b5.6400     0     2     20     15
vlan0105     32873     0019.07b5.6400     0     2     20     15
vlan0106     32874     0019.07b5.6400     0     2     20     15
vlan0107     32875     0019.07b5.6400     0     2     20     15
vlan0109     32877     0019.07b5.6400     0     2     20     15
vlan0111     32879     0019.07b5.6400     0     2     20     15
vlan0200     32769     001e.1477.e200     19     2     20     15     gi8/24
vlan0999     33767     0019.07b5.6400     0     2     20     15
Jon Marshall Wed, 03/03/2010 - 13:14
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Not sure how this relates to your original question. Is this now a different question ? BPDUGuard will do nothing to help you with your original problem.
Jon
ssamaharn Wed, 03/03/2010 - 13:18
Hi, Jon
It's the same question.  I was just reading about the BDPU guard on Cisco site yesterday about helping with spanning-tree.
Jon Marshall Wed, 03/03/2010 - 13:21
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
ssamaharn wrote:
Hi, Jon
BPDUGuard is used for ports that should not receive BPDUs on them ie. ports connected to devices such as client PCs/servers etc. It is no use for connections between switches because you want BPDUs to be sent and received on these ports.
Are you sure you are not thinking of rootguard which would help in making sure that your HP switches could not become the root switches ? You still need to sort out the STP root and secondary on your 6500 switches.
Jon
ssamaharn Wed, 03/03/2010 - 13:22
Should I do these command on my core1 and core2 ?
core1
spanning-tree vlan 1-111,999 root primary
core2
spanning-tree vlan 1-111,999 root secondray
Jon Marshall Wed, 03/03/2010 - 13:25
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
core1
core2
Yes, if these are all the vlans you have between the 6500 switches and the HP switches. But as already mentioned there will be a short outage while STP reconvergences so you need to schedule some downtime.
Jon
