CSA on CCX 7
Answered Question
Mar 2nd, 2010
I need to load the latest CSA onto a CCX7 server.  We do not have the Management Console.  What is the latest version that supports a standalone version of the CSA?
Overall Rating: 5 (1 ratings)
Aaron Harrison Wed, 03/03/2010 - 05:39
  • Community Spotlight Award,
    Member's Choice, May 2015
That PDF will list the supported versions for your version/SR of UCCX.
When you go to download it, you should find there are two available downloads - a 'Standalone' version (basically CSA with a canned policy specific for UCCX and CCM, which doesn't require the management console), and a downloadable policy for customers who have the full CSA product purchased.
Aaron
Please rate helpful posts...
Tony Knight Wed, 03/03/2010 - 17:25
At least I know I was looking tin the correct place....
When I go to download these, I do not get offered an option for a standalone version?
I went to the following URL:
http://tools.cisco.com/support/downloads/go/ImageList.x?relVer=5.2.0.282&mdfid=280962148&sftType=Security+Agent+%28CSA%29+Software&optPlat=&nodecount=7&edesignator=null&modelName=Cisco+Security+Agent+Version+5.2&treeMdfId=278065206&modifmdfid=null&imname=&treeName=Cisco+Security+Agent&hybrid=null&imst=null
Is there another place I should look for this?
