Common Services portal does not appear on the LMS 3.0 homepage
Mar 2nd, 2010
I am encountering a problem on Ciscoworks LMS 3.0 wherein the Common Services portal does not appear on the homepage. This was after I tried to upgrade CW to LMS 3.2 but does not seem to work so I revert back to LMS 3.0. I even did a restore of the backup database but still no Common Services on the homepage.
How do i resolve this?
Appreaciate your help. Thanks in advance!
Joe Clarke Tue, 03/02/2010 - 14:00
If you're not seeing the Common Services application portlet on the Functional Portal View, then you need to open a TAC service request to get the steps to manually re-register all of the installed applications from the command line.
benjo.rulloda Tue, 03/02/2010 - 14:05
Thanks Joe. Are the steps simple? Will it take long to resolve the problem?
Joe Clarke Tue, 03/02/2010 - 14:20
The process should be quick, but the steps are complicated (it will involve running a long CLI command repeatedly over a set of files).
