Vertical Dsiplay -- DMP4305
Mar 2nd, 2010
I am displaying an html from a PC running MRTG graphics but I'd like to display it in vertical mode. I've been looking at the options to do this in the users guide for both DMP and DMM but it's not that clear and also when I modify the recomended parameters in these guides nothing happens. You should know that I'm testing with DMS on VMWare.
I'd appreciate any information you would have about this.
Jeff Hostilo Wed, 03/03/2010 - 12:51
You can change the presentation orientation in the DMP settings under "Browser" then "Screen Rotation Angle". It gives you the option to have the DMP rotate the presentation by 90, 180 or 270 degrees clockwise.
