Sticky in ACE
Mar 2nd, 2010
I have ACE 4710, I have configured the load balancing for the Web Portal. But I am not able to configure the Stickness. Below is the configuation of load balancing.
rserver host ITSMWeb_1
  description ITSMWeb-1
  ip address 192.168.200.161
  inservice
rserver host ITSMWeb_2
  description ITSMWeb-2
  ip address 192.168.200.162
  inservice
serverfarm host SF_ITSM_Web_Server
  probe ITSMWeb_PROBE_80
  rserver ITSMWeb_1
    inservice
  rserver ITSMWeb_2
    inservice
sticky ip-netmask 255.255.255.255 address source ITSM-STICKY
  replicate sticky
  serverfarm SF_ITSM_Web_Server
class-map match-any ITSM_Web_Server
  2 match virtual-address 172.23.15.163 any
policy-map type loadbalance first-match PM_LB_ITSM_Web_Server
  class class-default
  class class-default
policy-map multi-match PM_ITSM_Web_Server
  class ITSM_Web_Server
    loadbalance vip inservice
    loadbalance policy PM_LB_ITSM_Web_Server
    loadbalance vip icmp-reply active
    nat dynamic 3 vlan 300
interface vlan 300
  description ACE-INSIDE CONTEXT RACK1
  ip address 192.168.0.65 255.255.255.224
  alias 192.168.0.73 255.255.255.224
  peer ip address 192.168.0.66 255.255.255.224
  no normalization
  mac-address autogenerate
  no icmp-guard
  access-group input acl-in
  nat-pool 1 172.23.16.2 172.23.16.2 netmask 255.255.255.255 pat
  nat-pool 3 172.23.16.3 172.23.16.3 netmask 255.255.255.255 pat
  nat-pool 4 172.23.16.4 172.23.16.4 netmask 255.255.255.255 pat
  nat-pool 5 172.23.16.5 172.23.16.5 netmask 255.255.255.255 pat
  service-policy input PM_ENOC_TP_Server
  service-policy input PM_RT_FAX
  service-policy input PM_ITSM_Web_Server
  service-policy input PM_ITSM_MAPP_Server
  service-policy input PM_BYPASS_FOR_LAN_HTTP
  service-policy input PM_BYPASS_HTTP
  service-policy input PM_MAIN_BCPROXY
  no shutdown
I can do the remote desktop, ping, telnet on port 80 but not able to get the sticky in function. Due to this stickiness my authentication is not working.
Please let me know what I am missing.
Overall Rating: 3 (1 ratings)
ciscocsoc Tue, 03/02/2010 - 23:55
  • Silver, 250 points or more
You've defined a sticky serverfarm, but you haven't created a policy that refers to it.
  class class-default
should read:
  class class-default
    sticky-serverfarm ITSM-STICKY
Cathy
David Niemann Thu, 04/29/2010 - 13:32
My experience with load balancing ITSM has been that you have to use the JSESSIONID for stickiness.
