Showing results forĀ
Search instead forĀ
Did you mean:Ā
Memory erros in cisco 2811 router
georgedipu
hi all,
I am getting below error message in my Cisco 2811 router
IOS of the router is:c2800nm-advsecurityk9-mz.124-4.T1.bin
Process= "Pool Manager", ipl= 0, pid= 5
-Traceback= 0x40C32960 0x400B0F98 0x400B66C8 0x400D1E18 0x4036FF40 0x400D54B4 0x
Mar  3 04:05:48.901: %SYS-2-MALLOCFAIL: Memory allocation of 65548 bytes failed
Pool: I/O  Free: 1655888  Cause: Memory fragmentation
Alternate Pool: None  Free: 0  Cause: No Alternate pool
-Process= "Pool Manager", ipl= 0, pid= 5
Mar  3 04:06:08.721: %CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSEC pa
        (ip) vrf/dest_addr= /255.255.255.255, src_addr= 0.0.0.0, prot= 17
Mar  3 04:06:18.914: %SYS-2-MALLOCFAIL: Memory allocation of 65548 bytes failed
Mar  3 04:06:48.926: %SYS-2-MALLOCFAIL: Memory allocation of 65548 bytes failed
Could you please suggest on the same
Dipu
Leo Laohoo
Can you upgrade your IOS and try again?
hi thanks for the reply
Current image is IOS of the router is:c2800nm-advsecurityk9-mz.124-4.T1.bin
I'd recommend you upgrade your IOS since you've got Memory Allocation Errors.
Troubleshooting Memory Problems
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_tech_note09186a00800a6f3a.shtml
Tharak Abraham
Level 3
Level 3
Dipu,
Pls paste a show mem summ or show process here if possible ?
Pls check the mem requirement for running this image
Some known bugs are still open and some crazy features can be held responsible for this too..-:)
Please open a Tac case too.
