WLC 4402
Mar 2nd, 2010
i have cisco wireless controller 4402 series, i wanted to upgrade it to higher versions, current version is 4.0.179.11, i wanted to go to version 6.x, i should go to mid version in between, but its refuse all the time the new image for some reasons which i dont know, there is 2 imgaes currently on the WLC pri and sec. and both are same version.
any one faced the same issue or know how to solve it?
Thanks and Regards
Majdi
Leo Laohoo Wed, 03/03/2010 - 13:25
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Have you gone through the release notes of the firmware you wanted to go to?  Kindly read the section posted below.  It will give you a brief description on the firmwares you need to install FIRST prior to full upgrade.
Special Rules for Upgrading to Controller Software
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn6_0_196.html#wp233853
MCIT- IT MCIT- IT Wed, 03/03/2010 - 23:29
I already checked the links attached , and went into the procedures step by step, the issue is when uploading the image file with tftp client, i am getting this error : Sanity check failed on file. The file was not downloaded completely , accourding to the manuals it means that the tftp not supporting more than 33 M files, i tried lot of TFTP softwares even the ons cisco recomends in the document tftpd32 i am getting the same error.
Leo Laohoo Thu, 03/04/2010 - 03:27
  • Hall of Fame,
    2017 LAN, Wireless
Try downloading the firmware again, maybe it's corrupt.
Scott Fella Thu, 03/04/2010 - 04:50
  • Hall of Fame,
    2017 Wireless
I use 3CDeamon and never had any issues.  You are also upgrading to 4.2.176.0 first correct?  Like leolaohoo mentioned, try to download the image again.
Scott Fella Mon, 03/08/2010 - 06:07
  • Hall of Fame,
    2017 Wireless
Try to tftp the image you currently have on your WLC and see if that fial or not.  Have you tried another PC/laptop with tftp?
Scott Fella Wed, 03/03/2010 - 11:25
  • Hall of Fame,
    2017 Wireless
Here is a document that will explain what version you can upgrade to from an existing version.  This should get you to 6.x
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00805f381f.shtml#conf
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
