How to firmware update a CISCO ATA 186 device in a "Cisco Unified CM Administration - System version: 7.0.1.11000-2" installation?
Answered Question
Mar 3rd, 2010
If I would like to upgrade the firmware on a CISCO ATA 186 device, in our "CISCO Unified CM Administration - System version: 7.0.1.11000-2" installation, how do I do this?
Where do I download the latest firmware update to the CISCO ATA 186 box, and where do I import this firmware and how do I deploy it to the CISCO ATA 186 device through the CISCO Unified CM Administration?
Kind regards,
Carl-Marius
Correct Answer by Jaime Valencia about 7 years 1 month ago
Bookmark this:
Download Software
http://tools.cisco.com/support/downloads/go/Redirect.x?mdfid=278875240
FWs for all phones are there.
Installation Notes
http://www.cisco.com/en/US/customer/docs/voice_ip_comm/cata/186_188/3_2_4/english/release/notes/atarn324.html#wp158141
Step 7 Double-click one of the downloadable files in Step 6, and click the Readme hyperlink, under the Additional Information section, which contains installation instructions for the corresponding firmware.
You can find the below links if you just search ATA 186 on www.cisco.com
How to Configure Cisco CallManager to Recognize ATA 186 Using SCCP
http://www.cisco.com/en/US/products/hw/gatecont/ps514/products_configuration_example09186a00800a892f.shtml
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Wed, 03/03/2010 - 07:50
  • Cisco Employee,
  • Hall of Fame,
    2011
Bookmark this:
Download Software
Installation Notes
java
Carl-Marius.Steensen Tue, 03/16/2010 - 01:03
Hi Javalenc,
Thank you for your help! - It was precisely what I was looking for
Kind regards,
Carl-Marius
Related Content
