Integrate B-ACD with UCM 6.1
Mar 3rd, 2010
Hi, I have a router 2821, I configured a B-ACD on the router and it's working fine (I can dial the CME extensions only). Now i want to dial the extensions of UCM 6.1 which is in the same network
the scenario as the following:
PSTN --> router 2821 with B-ACD --> extension 7132 on the UCM 6.1
is this doable or not?
Router IP 172.16.12.184
UCM 6.1 IP 172.16.35.20
application
service aa flash:app-b-acd-aa-2.1.0.0.tcl
  paramspace english index 1
  param number-of-hunt-grps 2
  param dial-by-extension-option 1
  param handoff-string aa
  paramspace english language en
  param max-time-vm-retry 2
  param aa-pilot 8025
  paramspace english location flash:
  param second-greeting-time 60
  param welcome-prompt _bacd_welcome.au
  param call-retry-timer 15
  param max-time-call-retry 700
  param voice-mail 5003
  param service-name queue
service queue flash:app-b-acd-2.1.0.0.tcl
  param queue-len 15
  param aa-hunt0 2222
  param queue-manager-debugs 1
archive
log config
  hidekeys
interface GigabitEthernet0/0
ip address 172.16.12.184 255.255.255.0
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
media-type rj45
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 172.16.12.1
ip http server
no ip http secure-server
control-plane
dial-peer voice 8025 voip
service aa
destination-pattern 8025
session target ipv4:172.16.12.184
incoming called-number 8025
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 7132 voip
destination-pattern 7132
session target ipv4:172.16.35.20
codec g711ulaw
telephony-service
max-ephones 3
max-dn 3
ip source-address 172.16.12.184 port 2000
auto assign 1 to 3
network-locale GB
network-locale 1 GB
network-locale 2 GB
network-locale 3 GB
network-locale 4 GB
max-conferences 12 gain -6
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  1  dual-line
number 5445
ephone-dn  2  dual-line
number 5446
ephone-dn  3  dual-line
number 5447
ephone  1
no phone-ui speeddial-fastdial
no phone-ui snr
no multicast-moh
mac-address 001A.6C7B.5726
type CIPC
button  1:1
ephone  2
no phone-ui snr
no multicast-moh
ephone  3
no phone-ui snr
no multicast-moh
ephone-hunt 2 longest-idle
pilot 2222
list 5445
paolo bevilacqua Wed, 03/03/2010 - 02:26
  • Hall of Fame,
    Founding Member
It should be possible, however not supported by cisco.
mrmhar1408 Wed, 03/03/2010 - 02:46
Thanks for replay but still i need answer for the question
paolo bevilacqua Wed, 03/03/2010 - 03:06
  • Hall of Fame,
    Founding Member
I have replied you above, what is that you do not understand ?
mrmhar1408 Wed, 03/03/2010 - 05:30
What is the solution? how can i make a call to UCM extension 7132. With the current configuration pasted above when i make call to 7132 it drops so is there something missing in this configuration?
Aaron Harrison Wed, 03/03/2010 - 06:10
  • Community Spotlight Award,
    Member's Choice, May 2015
Are you able to make normal CME IP phone to CallManager calls?
Have you added the CME gateawy to CallManager as a H.323 gateway by IP Address and reset it?
Aaron
mrmhar1408 Fri, 03/05/2010 - 22:04
Yes i can make call from IP phone registered with CME to IP phone registered with Callmanager and router is added as H323 gateway and is registered,
but i am unable to make any call from B-ACD to call manager IP Phone 7132
Aaron Harrison Sat, 03/06/2010 - 02:28
I see you have a dial-peer for 7132, however I don't see where you have programmed the B-ACD to use 7132?
You would need to add 7132 as the destination for a hunt group 'param aa-hunt1 7132' for example...
Aaron
mrmhar1408 Sat, 03/06/2010 - 05:26
application
  param aa-hunt1 7132
  param aa-pilot 8025
  param queue-len 15
  param aa-hunt0 2222
  param aa-hunt1 7132
archive
log config
  hidekeys
duplex auto
speed auto
media-type rj45
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
pvc 0/35
  pppoe-client dial-pool-number 1
interface ATM0/1/0
no ip address
pvc 0/35
  pppoe-client dial-pool-number 2
interface ATM0/2/0
no ip address
pvc 0/35
  pppoe-client dial-pool-number 3
interface Serial0/3/0
no ip address
shutdown
clock rate 2000000
interface Dialer1
ip address negotiated
ip mtu 1492
encapsulation ppp
dialer pool 1
ppp authentication chap callin
ppp chap hostname 66100016786@256.saudi.net.sa
ppp chap password 0 81753092
interface Dialer2
ip mtu 1492
encapsulation ppp
dialer pool 2
ppp chap hostname 90850513949@256.nesma.net.sa
ppp chap password 0 42834432
interface Dialer3
ip mtu 1492
encapsulation ppp
dialer pool 3
ip http server
control-plane
service aa
codec g711ulaw
no vad
codec g711ulaw
dial-peer voice 1532 voip
destination-pattern 1532
session target ipv4:172.16.100.40
codec g711ulaw
telephony-service
max-ephones 3
max-dn 3
auto assign 1 to 3
network-locale GB
network-locale 1 GB
network-locale 2 GB
network-locale 3 GB
network-locale 4 GB
number 5445
number 5446
number 5447
ephone  1
no phone-ui snr
no multicast-moh
type CIPC
button  1:1
ephone  2
no phone-ui snr
no multicast-moh
ephone  3
no phone-ui snr
no multicast-moh
pilot 2222
list 5445
where exactly you want me to change the configuration??
mrmhar1408 Sat, 03/13/2010 - 23:10
the problem solved
the voice service voip solve the problem, why it solve the problem although the dialpeers working with H.323 that is I don't know
mserwon Mon, 04/12/2010 - 11:46
I am trying the same thing B-ACD to UCM.  Sounds like you got it working to your 7132 number.  What did you do to voice service voip to solve the problem?  Can you post a config?
mserwon Mon, 04/12/2010 - 12:04
I just got it working.  I added the allow-connections h323 to h323 in the voice service voip.
