Junk characters on ASA Console
Mar 3rd, 2010
I am seeing Junk characters as seen when the Bits/sec is set wrongly.
I am sure i am using the correct Line speed etc stuff, as the same console cable moved to another ASA works fine.
Tried realoading the ASA to see if that helps but no luck.
Any ideas?
Kureli Sankar Wed, 03/03/2010 - 05:53
What code is the ASA running?
What junk characters are you seeing?
Could you pls. copy and paste?
Once the ASA comes up are you able to telnet or ssh to it?
victor_87 Wed, 03/03/2010 - 08:51
Code ===> 7.2(4)
Junk ====>    ìsS>L['x¹ûÊÃKLâþ&j‹?È=÷NÝK&,Õ–ÇÂjŠú1‹þ'ª10Ó85ª¸1B « C-SßC7¢×" == screenshot attached
ASA is all fine, Traffic flowing well. failover with the other ASA is good as well.
