Critical alarm : actastor_watchdog the service has been disabled
Mar 3rd, 2010
I have a major alarm on a WAVE-274 (Edge-WAAS).
Alarm: "nodemgr: actastor_watchdog the service has been disabled"
Is it possible to learn more about this - what caused it, ect.
Any ideas on how to proceed?
ohaddad Wed, 03/03/2010 - 04:22
On the same Edge-device, i have two others critical alarms :
Alarm 2: "device_mgr service has been disabled"
Alarm 3: "the Wafs_edge service has been disabled"
Zach Seils Wed, 03/03/2010 - 09:33
  • Cisco Employee,
A few questions:
  • What version of WAAS are you running?
  • Was this device recently upgraded?
  • Is other traffic (besides CIFS) being optimized without any problems?
Can you provide the syslog.txt and a tech-support from the device?
Zach
ohaddad Fri, 03/05/2010 - 02:01
Hello Zach,
Can you chek your inbox please.
Patrick Moubarak Fri, 03/05/2010 - 06:08
  • Bronze, 100 points or more
I saw this issue more than once with WAAS 4.1.5c; it was a bug that caused the WAFS AO to stop accelerating traffic. Fortunately it seems to have been fixed in 4.1.5d according to the release notes.
The bug id is:
CSCtd60131
Device reporting alarm "actastor_watchdog service has been disabled"
I haven't had this issue with 4.1.5d...
Patrick
eoinpower Thu, 10/14/2010 - 18:51
I am also experiencing this issue with one of my wae-502 which is running 4.1.5f, I have tried disabling and re-enabling cifs service but it reappears with the same alarm after it has initilized.
Accelerator     Licensed        Config State    Operational State
cifs            Yes             Enabled         Disabled
epm             Yes             Enabled         Running
http            Yes             Enabled         Running
mapi            Yes             Enabled         Running
nfs             Yes             Enabled         Running
ssl             Yes             Enabled         Running
video           No              Enabled         Shutdown
wafs-core       Yes             Disabled        Shutdown
wafs-edge       Yes             Disabled        Shutdown
Patrick Moubarak Fri, 10/15/2010 - 07:21
If you are encountering bug CSCtd60131then you need to upgrade to 4.1.7a or 4.2.1 or later. Otherwise you can contact the TAC for a script to recover from this problem. Check the release notes and check the bug ID in the Software Bug Toolkit (registered users only) for more details
Patrick
