Router 7609 and 7609-S
Answered Question
Mar 3rd, 2010
Hellos friends, I have recently bought a Cisco router 7609-S but unfornutately I receive a 7609. Besides the obvious shipping problem, I want to know wich is the differences between the two of them?...For more information I have 2RSP720-3C on the chassis. Thanks for your help.
Correct Answer by Reza Sharifi about 6 years 10 months ago
Hello Jonas,
From the data sheet:
As part of the Cisco 7600 Series, the Cisco 7609-S Router is an enhancement on the highly successful 9-slot chassis (Cisco 7609). This enhanced chassis delivers numerous design improvements, including:
• Improved failover mechanisms in the hardware which when paired with the proper Cisco IOS® Software image, can achieve 100 ms failover
• Ability to deliver higher power of up to 750W per slot
• Redundant high-speed fan tray module with five speeds on a front-to-back airflow design
• Better thermal flow measurement and management
The power supplies supported on the Cisco 7609-S are the 4000W, 6000W (AC and DC), and 3000W AC power supplies (refer to Table 1).
Also, here are the data sheets for both 7609 and 7609-S
Reza
Overall Rating: 5 (1 ratings)
Correct Answer
Reza Sharifi Wed, 03/03/2010 - 05:46
Hello Jonas,
Reza
Related Content
