Restore problem on ASA5505
Mar 3rd, 2010
Hi, I have a problem with restore config on Cisco ASA5505, on the first 5505 I have made a config backup form the GUI:
tool --> backup configuration --> backup all
now on the second ASA5505 (with the factory value) from the GUI:
tool --> restore configuration --> --> restore all
the restore procedure is completed without error, then 'reload' but the configuration isn't changed !
the ip address and the all others settings aren't changed.
Collin Clark Thu, 03/04/2010 - 06:42
I don't use ASDM, but there should be a Save button that you'll need to click to save the configuration. You could go to the CLI and type write memory and that would save the config.
Hope it helps.
pixteam2007 Fri, 03/05/2010 - 01:52
Hi, I have tried with 'Save' and 'write memory' but with both command the configuration isn't changed, then I have used the CLI with tftp server and the restore procedure is ok ! but with GUI the problem is always present.
