Is it possible to see the original calling number before the agent answers the call?
Answered Question
Mar 3rd, 2010
When ICD does a consult transfer from ICD to the Agent, the agent device will show calling number as the CTI Port during ringing. Upon answer it will display the original calling number when the consult transfer is completed.
Evgeney.
Correct Answer by Aaron Harrison about 7 years 2 months ago
The system is effectively doing a Consult Transfer to the agent; this allows it to retract the call if the agent doesn't answer.
It's not possible to change this behaviour.
If you are using Agent software on the PC, you should be able to see the caller's number in the data panel.
Aaron
Please rate helpful posts...
Overall Rating: 5 (1 ratings)
Correct Answer
Aaron Harrison Wed, 03/03/2010 - 07:28
  • Community Spotlight Award,
    Member's Choice, May 2015
Aaron
