Error - Fail to set vlan in driver [F1ControlPlane::cmgrSscGetVlan]
Mar 3rd, 2010
We have a ASA 5520 with 2 IPS's. Received the following error in the ASA-IPS.  Any suggestions would be greatly appreciated.
evError: eventId=1265315511818687793  vendor=Cisco  severity=error
  originator:
    hostId: wps-asa-ips2
    appName: mainApp
    appInstanceId: 16855
  time: Mar 03, 2010 14:44:32 UTC  offset=-300  timeZone=GMT-05:00
  errorMessage: Error - Fail to set vlan in driver [F1ControlPlane::cmgrSscGetVlan]  name=errUnclassified
IPS Version : 7.0(2)E3
Device Type : ASA-SSM-20
JMC Nel Wed, 03/03/2010 - 07:59
solved :
That message is due to cosmetic defect CSCtc89228. Its not of concern
problem-wise (its only cosmetic), and is usually produced when ASDM is
used to manage the sensor. A potential workaround is to ensure that a
nameif statement is added to the ASA Management interface (in the ASA
config):
http://www.cisco.com/en/US/docs/security/asa/asa80/command/reference/no.html#wp1747183
F1 Control Plane error message on SSM
Symptom:
AIP-SSM generates the following error:
evError: eventId=1258430054000390184 vendor=Cisco severity=error
originator:
hostId: HOSTID
appName: mainApp
appInstanceId: 426
time: Nov 17, 2009 15:06:52 UTC offset=-300 timeZone=GMT-05:00
Conditions:
Seen in 7.0(2)E3.
Workaround:
No known workaround at this time.
