"Show Inventory Raw" doesn't display serial numbers for GBICS on..
The "Show Inventory Raw" command doesn't display serial numbers for GBICS on my second WS-6516 blade on my 6509.  Is there a way to retrieve this information?
5 Replies 5
Ganesh Hariharan
You can determine the serial number of the chassis and other components       with use of the show idprom command
Try with command Switch#show idprom interface
Hope to help !!
Ganesh.H
That command will come in handy, but it won't retrieve information from any of the (16) interfaces on that module.
ITN7_6509#show idprom module 2
IDPROM for module #2
  (FRU is 'SFM-capable 16 port 1000mb GBIC')
  OEM String = 'Cisco Systems'
  Product Number = 'WS-X6516A-GBIC'
  Serial Number = 'STT1242029N'
  Manufacturing Assembly Number = '73-9052-06'
  Manufacturing Assembly Revision = 'A0'
  Hardware Revision = 4.6
  Current supplied (+) or consumed (-) = -3.62A
ITN7_6509#show idprom interface gigabitEthernet 2/1
Unable to retrieve idprom information
ITN7_6509#
Do you think this is a physical layer issue?
ITN7_6509#
It' really strange as show inventory raw command, which retrieves information about all of the Cisco products installed in the networking device, even if the entities do not have a product ID (PID) value.
Chek out the below link for determining the serial numbers of component for switches,Hope to help
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00801c1e9a.shtml
Ganesh.H
THat s/n doesn't seem to be a Cisco-approved GBIC.
I found that the hardware version is different on the two modules. The first module has a version of 4.6 while the second is 4.7.
