UCCX Custom Report, Crystal Report datasource issue.
Mar 3rd, 2010
I recently developed some custom reports for a client and had the unfortunate mistake of following the official guide for their creation. As a result, my reports are rendered useless outside of my development workstation. I opened up the standard reports, determined the datasources and commands I needed to make mine work, changed them over (see screenshot attached) but they still result in error 5022 in Historical Reporting Client.
I would like to know if anyone has any suggestions before I redo the entire reports from scratch to make them work properly.
UCCX 7.0(1)SR5
Crystal Reports XI Developer Edition R2 SP4
Cheers,
Tanner Ezell
Tanner Ezell Wed, 03/03/2010 - 08:29
Aaron,
Looks like we had the same solution, unfortunately for me it doesn't
seem to work after changing it over.
Cheers
Tanner Ezell
On Wed, Mar 3, 2010 at 11:25 AM, aaronharrison
Aaron Harrison Wed, 03/03/2010 - 08:33
If you want to send me the report/procedure I can probably fix it for you.
Aaron
Tanner Ezell Wed, 03/03/2010 - 08:45
Sure, where would be a good place to send it?
On Wed, Mar 3, 2010 at 11:33 AM, aaronharrison
Tanner Ezell Wed, 03/03/2010 - 08:34
Oops, the CR Datastore is from the new report and works properly. The screen shot picture shows the 'fixed' report (also mirrors what you had posted) but still results in an error.
I'd really appreciate some insight you have in regards to this.
