Multiple VPN connections using 871 router
Answered Question
Mar 3rd, 2010
  I have a cisco 871 router at retail site which connects to the corporate site. I also want to connect a partner device sharing the network, but it should connect to their VPN.  Is it possible to configure 2 VPNs connecting to 2 different company sites in this scenario ?
Thanks for your help.
Umesh.
Correct Answer by Federico Coto F... about 6 years 11 months ago
You can configure multiple VPN tunnels on the router (either on the same interface or on different interfaces).
You can then make the traffic received from one tunnel into another tunnel if you need to do that as well.
Federico.
Overall Rating: 5 (1 ratings)
Correct Answer
Federico Coto F... Thu, 03/04/2010 - 12:58
Federico.
