Unity Connection User " 0 Out" Feature
Mar 3rd, 2010
Where in Unity Connection do you define the "0 Out" feature to all allow callers to transfer to an opeator or another extension without leaving a message?
Rob Huffman Wed, 03/03/2010 - 10:37
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hey Arthur,
Go to the user and edit "Caller Input" for 0 and send caller to
the desired directory number.
Cheers!
Rob
arthurbecker Wed, 03/03/2010 - 10:48
I believe that is for standard Unity.
This is for Unity Connection 7.x. I have no fields refering to "Caller Imput" under the Users section.....
Rob Huffman Wed, 03/03/2010 - 11:02
  • Hall of Fame,
    Founding Member
Hi Arthur,
No, this is from Unity Connection 7.1 which is what we are running as well
If you bring up a User (yourself for example) and then click on Edit> the 7th
selection down from the top of the list should be Caller Input. This is where the Dial 0
would be set.
Cheers!
Rob
arthurbecker Wed, 03/03/2010 - 11:11
Ahhh, thank you Rob! I see that is a drop down under Edit. i never saw this feature before.
   Thanks again, Art
