How to remove UCM 7.x Publisher domain name.
Mar 3rd, 2010
We need to remove publisher from domain.  we had previously added in UCM via set network domain exampledomain.com
I tried "set network domain" (then no characters, i.e. blank spaces) and it does not take.
We do not want publisher tied to domain.  Is there a way to undue this?
thanks,
Tommer Catlin Wed, 03/03/2010 - 11:15
  • Green, 3000 points or more
Technically, its not really tied to a domain anyways.  Its not like an AD domain or PC.  The domain name is put in there so when you create the Security Certs from the Publisher, the domain name is filled in.  IE   publisher.examplecompany.com on the cert.  So the it matches all the way through.
You may see it show it up on CDP on the connected switch as a neighbor.  But you should not see it anywhere else.
I think you have to set a no statement on the network domain name.  Reboot.  Then set the domain and reboot again. (I cant recall though)
Someone else may more info on this, but typically, I ignore whatever is in the domain name of the pub *UNLESS* it is used for SSL certs or CUPS (SIP uses the domain name of the machine also)
m.batts Fri, 06/22/2012 - 02:35
  • Bronze, 100 points or more
I have a similiar question.There isn't away of removing this command using "no".Did anyone else figure out how to remove the domain or do we not need to worry about it.
cheers
Mark
m.batts Fri, 06/22/2012 - 03:08
If anyone is interested
Post 8.03  unset network domain
Pre 8.03 set network domain ""
