Network Compliance Manager EoS/EoX
Answered Question
Mar 3rd, 2010
I know that there are a lot of discussions about EoS/EoX not working on other software packages (LMS and/or RME) but I would like to add Network Compliance Manager to the list. We generate reports on the first of each month and it has been a couple months since we have gotten a successful report.
Are there any logs that I could include that would be of any help in identifying this issue?
AJ Schroeder
Correct Answer by Joe Clarke about 7 years 3 months ago
I believe the same patch will be applicable to NCM (but I do not support NCM).  So the same ETA would apply (i.e. 3/16).
Overall Rating: 5 (1 ratings)
Joe Clarke Wed, 03/03/2010 - 12:22
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I believe NCM is using the same interface as RME, and thus is affected by the same problem.
AJ Schroeder Wed, 03/03/2010 - 13:18
I figured as much, but just wanted to add that to the list of apps that aren't working.
Is there an ETA?
Correct Answer
Joe Clarke Wed, 03/03/2010 - 15:35
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
dmamattah Wed, 03/31/2010 - 10:03
has Cisco released the patch yet? i need to run this report asap
thanks
AJ Schroeder Wed, 03/31/2010 - 10:44
I loaded the service pack for NCM (1.5.1) and EoS/EoX is
still failing! At least this time it is with a different error:
Exception in thread "main" java.lang.NullPointerException
at com.cisco.nm.lib.eox.util.PopulateEoxDeviceInfoUsingAG.skip(PopulateEoxDeviceInfoUsingAG.java:105)
at com.cisco.nm.lib.eox.util.PopulateEoxDeviceInfoUsingAG.createEoxModuleInfos(PopulateEoxDeviceInfoUsingAG.java:62)
at com.cisco.nm.lib.eox.util.PopulateEoxDeviceInfoUsingAG.populateEoxDeviceInfo(PopulateEoxDeviceInfoUsingAG.java:45)
at com.cisco.nm.cwncm.eox.EoxUtils.populateDevice(EoxUtils.java:138)
at com.cisco.nm.cwncm.eox.EoxUtils.getEoxDeviceInfosEx(EoxUtils.java:84)
at com.cisco.nm.cwncm.eox.EoxReportGenerator.main(EoxReportGenerator.java:333)
Related Content
