WLC redundancy
Answered Question
Mar 3rd, 2010
I have a question about the wlc with the following scenario:
1- I have two 50 APs WLAN Controllers (WLC1, WLC2).
2- I have 20 APs in total.
3- The APs are configured with primary and secondary WLC.
4- Ten of the 20 APs are associated to WLC1 as primary.
5- The other ten APs are associated to WLC2 as secondary.
I need to know what would happen with the APs associated to the WLC1 if the WLC1 fails?.
How fast will be the reassociation to the WLC2.
Are the tcp/udp/etc conections broken?.
Its a possible solution for redundancy?.
Correct Answer by George Stefanick about 7 years 3 weeks ago
Good question. The AP will drop for 5 seconds, flash colors and go right to green (when  no one is associated or deep blue if someone associates right away).
You can test this ... take a test ap, put it on WLC1 then change the primary to WLC2 and enable AP Fall back ... You will see the AP move over to the other controller in a minute or so ...
In any case, you break the LWAPP tunnel and the AP rejoins a new controller and establishes a new tunnel.
Overall Rating: 5 (1 ratings)
Leo Laohoo Wed, 03/03/2010 - 13:12
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
DO you have HREAP enabled?
What firmware are you running?
Correct Answer
George Stefanick Wed, 03/03/2010 - 17:57
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
