tel 6921 vs CME like SRST 7.1
Mar 3rd, 2010
hi, i have several 6921 ip phones, and they work fine with a CUCMBE 7.1.2, but when i check the CME like SRST, they cannot register properly, the version of the CME is 7.1, is there any way to put them to work with CME 7.1 like SRST.  i dont have any changes to change the IOS of the router to upgrade it to CME 8.X
thanks in advanced.
Bruno rangel Thu, 03/17/2011 - 16:37
Hi guys
How I make this upgrade to support 69xx phones?
I'm using CUCM 7.1 and Router 2911.
pratik.rb Sat, 03/19/2011 - 09:09
You will need an IOS which has CME/SRST ver 8.0
Typically 15.1T upwards
Bruno rangel Wed, 03/23/2011 - 16:51
Hi Pratick thanks for reply.
One more question.
I just save the new IOS with on the flash of Router?
pratik.rb Thu, 03/24/2011 - 09:09
Yes.
Before upgrading you have to consider the IOS hardware requirements i.e. DRam/Flash.
You have to upgrade the IOS on router by putting the IOS file on the router flash by using copy tftp: flash: command and then configure the router to boot with it by "boot system flash: command from global config.
