03-03-2010 02:02 PM
We are having issues with truncating packets that go through the CSS
I did a capture after the CSS and there is truncation............however i cant read it before the since everything is encrypted.
They hit vip address 172.20.120.16. on the CSS and get redirected to 2 servers depening on what the url says
They server team would like to turn it off just to test..i tried removing
"add service ARR-public-ssl" from the contetn below and we lost http and https to the server
so in essence i want to try and turn the 443 connection to a port 80---than it goes to port 7777 backend to 172.20.212.6
content BYE-WEB-SSL
protocol tcp
port 443
advanced-balance ssl
application ssl
active
ssl-server 40
ssl-server 40 rsacert byetest
ssl-server 40 vip address 172.20.120.16
ssl-server 40 cipher rsa-with-rc4-128-sha 172.20.120.17 80
ssl-server 40 cipher rsa-with-rc4-128-md5 172.20.120.17 80
ssl-server 40 urlrewrite 1 *
ssl-server 40 cipher rsa-with-3des-ede-cbc-sha 172.20.120.17 80
ssl-server 40 rsakey byekey
backend-server 50
backend-server 50 type initiation
backend-server 50 server-ip 69.xxx.xxx.xxx
backend-server 50 ip address 69.xxx.181.xxx
backend-server 50 rsacert byetest
backend-server 50 rsakey byekey
active
!************************** SERVICE **************************
service TIE-SSLINIT
protocol tcp
ip address 69.xxx.xxx.xxx
keepalive type tcp
keepalive port 443
slot 2
type ssl-init
add ssl-proxy-list HR-SSL
active
owner PublicBYE
content BYE-WEB-ARRR
vip address 172.20.120.17
protocol tcp
port 80
url "/arr*"
advanced-balance arrowpoint-cookie
balance aca
arpt-lct http-100-reinsert
add service BYE-ods-web1
active
content BY-WEB-TIX
protocol tcp
port 80
url "/tix*"
balance aca
add service BYE-ods-web2
active
content BYE-WEB-TIX-CLEARTEXT
add service TIX-SSLINIT
vip address 172.20.120.19
protocol tcp
port 80
active
content BYE-WEB-Nav
protocol tcp
port 80
url "/na*"
balance aca
active
content BYE-WEB-SSL
protocol tcp
port 443
application ssl
active
service BYE-ds-web1-ssl
ip address 172.20.212.5
port 443
keepalive type ssl
active
service BYE-ds-web2
ip address 172.20.212.6
port 7777
keepalive port 7777
keepalive type tcp
active
service BYE-ds-web2
port 7777
keepalive port 7777
keepalive type tcp
active
service BYEos-web2-ssl
port 443
keepalive type ssl
active
03-04-2010 12:46 AM
" want to try and turn the 443 connection to a port 80"
You can't do this without decrypting the traffic with the SSL module.
You could try going to your :80 rule directly in cleartext (HTTP) and see if it works.
Or you can send the HTTPS traffic to your server assuming they can decrypt it.
What version do you run on the CSS ?
Do you have the sniffer trace where we can see the packets being truncated ?
I can have a look.
Doing config changes will not help you understand the problem.
You first need to define the problem exactly and then apply the correct solution.
Trial and error is not a good troubleshooting approach.
Gilles.
03-04-2010 06:50 AM
CSS11506# sh ver
Version: sg0810205 (08.10.2.05)
Flash (Locked): 08.10.1.06
Flash (Operational): 08.10.2.05
Type: PRIMARY
Licensed Cmd Set(s): Standard Feature Set
Secure Management
Yeah..if done a packet trace before it hits the CSS and after......the only issue is that everything is engrypted before it hits the LB so i cant really read anythign....i did a pacet trace after the LB and on the Server itself its seems we get this
I thought i saw some bug info from cisco but i cant tell if its related
CSCsx05640—When you configure the CSS for a Layer 5 (L5) content rule and it receives an HTTP method POST with the HTTP header in one packet that is quickly followed by many packets of POST data or payload, it could fail to deliver all the data to the back-end server. The CSS Flow Manager (FM) application could incorrectly handle the POST and the data packet as a spanned content request and could cause the data to be mishandled. Workaround: Use less than 1-Gb connections in the network; a 100-Mb link does not exhibit this issue.
As you can see after the content-length..........nothing comes across........sometimes addtional stuff will come in ...but usually nothing
Is there a bug related to this on the CSS?
POST /TIXX/DocumentRepository_Service HTTP/1.1
Accept-Encoding: gzip,deflate
Content-Type: application/soap+xml;charset=UTF-8;action="urn:ihe:iti:2007:ProvideAndRegisterDocumentSet-b"
User-Agent: Jakarta Commons-HttpClient/3.1
Host: www.xxxxxxxxxxxx.net
Content-Length: 9044
