Shaping GigE Interface to OC-12 Pipe
Answered Question
Mar 3rd, 2010
We have an OC-12 circuit (622Mbps) connected to our router's gigE interface (inter g1/0). Although the physocal interface is 1000Mbps the actual line speed is 622Mbps. If I get an offer load of 1 gig of data going through the interface, only 622Mb will be processed, while the remaining 378Mb will get queued or dropped. Does anyone have a shaping "configuration" that will shape/buffer the traffic once it it's 622Mbps.
My primary goal is to prevent ouput drop on the gigE interface as much possible. Thanks in advance.
Correct Answer by Giuseppe Larosa about 7 years 4 months ago
Hello David,
be aware that outbound shaping is not supported on all platforms for example on a standard GE port of a C6500/7600 just to make an example.
It is supported on routers and on WAN oriented modules of C6500/7600
Hope to help
Giuseppe
Correct Answer by Jerry Ye about 7 years 4 months ago
Please specify what type of router? Shaping config should be similar to the following
policy-map SHAPE
class class-default
  shape average 622000000
interface xxxx
service-policy out SHAPE
HTH,
jerry
Overall Rating: 5 (1 ratings)
Correct Answer
Jerry Ye Wed, 03/03/2010 - 18:11
  • Cisco Employee,
policy-map SHAPE
class class-default
interface xxxx
HTH,
jerry
Correct Answer
Giuseppe Larosa Thu, 03/04/2010 - 05:11
  • Hall of Fame,
    Founding Member
Hello David,
Hope to help
Giuseppe
davidhuynh5 Thu, 03/04/2010 - 14:45
Thanks Giuseppe. I found that out today when I tried to configure it on an interface and it can back
"not supported on this interface" :-(
Jerry Ye Thu, 03/04/2010 - 15:14
  • Cisco Employee,
Hi David,
That was my first question to you initially "Please specify what type of router?".
jerry
