Number of translation rules supported by a voice gateway
Mar 3rd, 2010
Hi All
Any one know how many translation rules we can configure in a voice gateway. I know we can configure 15 subrules under one rule. Please help me to find answer.
Thank you
Overall Rating: 3 (2 ratings)
shaunswales Thu, 03/04/2010 - 00:57
Hi Siraj
First of all, what platform are you using as your voice gateway? Hardware specs (memory) and IOS?
Another thing, you can use the num-exp command to do translations on the gateway
For example:
num-exp 0555 0825555555
num-exp 05.. 0825555555
This will catch incoming calls destined for 0555 and expand them to 0825555555. You can also wildcard as per the 2nd example.
Hope this helps
Aaron Harrison Thu, 03/04/2010 - 01:12
You can configure 15 rules in a rule, and you can apply multiple rules to a profile.
You can then have multiple profiles applied to multiple dial peers, so the answer is ... a lot.
I've never hit a limit.
Please rate helpful posts...
sirajuddeen t p Thu, 03/04/2010 - 01:51
Hi Gentlemen
Thank you very much for the update. I am using cisco 2821 ISR with 12.4 IOS. I want to know how many master rules we can create on a gateway. We can have 15 subrules.
Thank you
