AS5350 license
Answered Question
Mar 4th, 2010
Pls, how can I discover which license I have on AS 5350 through CLI. Here is my sh ver:
xxxx#sh ver
IOS (tm) 5350 Software (C5350-IS-M), Version 12.2(2)XB3, EARLY DEPLOYMENT RELEASE SOFTWARE (fc2)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Sun 10-Feb-02 00:31 by hwcheng
Image text-base: 0x600089C8, data-base: 0x61180000
ROM: System Bootstrap, Version 12.2(1r)1, RELEASE SOFTWARE (fc1)
BOOTLDR: 5350 Software (C5350-BOOT-M), Experimental Version 12.1(20000922:142008) [nag-flo_t_0110 101]
xxxx uptime is 2 days, 3 hours, 2 minutes
System restarted at 09:35:52 utc Wed Feb 24 2010
System image file is "flash:c5350-is-mz.122-2.XB3.bin"
cisco AS5350 (R7K) processor (revision T) with 131072K/65536K bytes of memory.
Processor board ID JAE070206Y0
R7000 CPU at 250Mhz, Implementation 39, Rev 1.0, 256KB L2, 2048KB L3 Cache
Last reset from power-on
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Primary Rate ISDN software, Version 1.1.
Manufacture Cookie Info:
EEPROM Type 0x0001, EEPROM Version 0x01, Board ID 0x32,
Board Hardware Version 3.33, Item Number 800-5171-02,
Board Revision B0, Serial Number JAE070206Y0,
PLD/ISP Version 2.2,  Manufacture Date 7-Jan-2003.
Processor 0x14, MAC Address 0x0B46825FEA
Backplane HW Revision 1.0, Flash Type 5V
2 FastEthernet/IEEE 802.3 interface(s)
64 Serial network interface(s)
60 terminal line(s)
2 Channelized E1/PRI port(s)
512K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
8192K bytes of processor board Boot flash (Read/Write)
Correct Answer by Paolo Bevilacqua about 7 years 3 weeks ago
As mentioned above, licenses are paper only and do not show with any command whatsoever.
Please remember to rate useful posts clicking on the stars below.
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Fri, 03/05/2010 - 15:09
  • Hall of Fame,
    Founding Member
It won't show, licenses are paper only.
mljevakovic Sun, 03/07/2010 - 11:34
Is it possible to now it in any other way than paper, I mean through sh tech, sh diag any command etc...(We have NP60 DFC card inside AS5350.)
Thanks in advance.
Correct Answer
Paolo Bevilacqua Mon, 03/08/2010 - 11:25
  • Hall of Fame,
    Founding Member
