Ciscoworks LMS 3.0.1 RME devices management
Answered Question
Mar 4th, 2010
Hello everyone,
I work with CW LMS 3.0.1 with the following product versions installed:
Products Installed
Showing 1-8 of 8 records
Product Name
Version With Patch Level
Installed Date
1.
CiscoWorks Common Services
3.1.1
02 Mar 2010, 10:34:04 CET
2.
Campus Manager
5.0.2
02 Mar 2010, 10:34:05 CET
3.
CiscoView
6.1.7
02 Mar 2010, 10:34:10 CET
4.
CiscoWorks Assistant
1.0.1
5.
Device Fault Manager
3.0.5
02 Mar 2010, 14:55:12 CET
6.
Internetwork Performance Monitor
4.0.1
02 Mar 2010, 10:34:14 CET
7.
LMS Portal
1.0.1
02 Mar 2010, 10:34:17 CET
8.
Resource Manager Essentials
4.1.1
02 Mar 2010, 10:34:18 CET
Many Thanks in advance,
Luca
I verified that RME has a license to support 1500 devices while the devices discovered by RME are about 1600.
Many of these devices have now been eliminated from the Network (around 200) and I want to know if there is a way to automatically remove them from CW or if I must remove them manually step by step.
Correct Answer by Joe Clarke about 6 years 10 months ago
In LMS 3.0.1, you must remove them manually.  LMS 3.2 has a feature which can poll devices in DCR, then generate a report for those which are no longer reachable.  That will then facilitate removing those devices.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Thu, 03/04/2010 - 11:39
