03-04-2010 01:22 AM - edited 03-19-2019 12:33 AM
Hi all,
I am new in the cme world.
I am trying to set a lab enviroment and i want to use and S0 from my pbx (Alcatel omnipcx) to simulate call between my extension and some ip phone.
this is my BRI config,
interface BRI0/2/0
no ip address
isdn switch-type basic-net3
isdn overlap-receiving
isdn incoming-voice voice
isdn static-tei 0
end
voice translation-rule 1
and when i call from my alcatel extension (397) to the S0 extension (136) i can view this on the cme.
#sh voice call status
CallID CID ccVdb Port DSP/Ch Called # Codec Dial-peers
0x17A 121F 0x86619220 0/2/0.1 0/1:1 136 None 9/41
0x17B 121F 0x86619220 0/2/0.0 *136 None 41/9
1 active call found
1 active call found
0x17C 1220 0x86619220 0/2/0.1 0/1:1 136 None 9/4
0x17D 1220 0x86619220 0/2/0.0 *136 None 4/9
1 active call found
#sh call active voice
Telephony call-legs: 1
SIP call-legs: 0
H323 call-legs: 0
Call agent controlled call-legs: 0
SCCP call-legs: 0
Multicast call-legs: 0
Total call-legs: 1
GENERIC:
SetupTime=75503840 ms
Index=1
PeerAddress=397
PeerSubAddress=
PeerId=9
PeerIfIndex=44
LogicalIfIndex=2
ConnectTime=0 ms
CallDuration=00:00:00 sec
CallState=3
CallOrigin=2
ChargedUnits=0
InfoType=speech
TransmitPackets=0
TransmitBytes=0
ReceivePackets=0
ReceiveBytes=0
TELE:
ConnectionId=[0xF4D27044 0x266111DF 0x80310021 0xA02B1560]
IncomingConnectionId=[0xF4D27044 0x266111DF 0x80310021 0xA02B1560]
CallID=348
GlobalCallId=[0xF4D27044 0x266111DF 0x80310021 0xA02B1560]
Port=0/2/0 (348)
BearerChannel=0/2/0.1
TxDuration=0 ms
VoiceTxDuration=0 ms
FaxTxDuration=0 ms
CoderTypeRate=None
NoiseLevel=0
ACOMLevel=0
OutSignalLevel=0
InSignalLevel=0
InfoActivity=0
ERLLevel=0
SessionTarget=
ImgPages=0
CallerName=
CallerIDBlocked=False
LongDurationCallDetected=no
LongDurCallTimeStamp=
LongDurCallDuration=
OriginalCallingNumber=397
OriginalCallingOctet=0x9
OriginalCalledNumber=136
OriginalCalledOctet=0x81
OriginalRedirectCalledNumber=
OriginalRedirectCalledOctet=0xFF
TranslatedCallingNumber=397
TranslatedCallingOctet=0x9
TranslatedCalledNumber=136
TranslatedCalledOctet=0x81
TranslatedRedirectCalledNumber=
TranslatedRedirectCalledOctet=0xFF
GwReceivedCalledNumber=136
GwReceivedCalledOctet3=0x81
GwReceivedCallingNumber=397
GwReceivedCallingOctet3=0x9
GwReceivedCallingOctet3a=0x80
DSPIdentifier=0/1:1
SIP call-legs: 0
H323 call-legs: 0
SCCP call-legs: 0
Total call-legs: 1
03-09-2010 03:21 AM
In other words, what is the problem ?
03-09-2010 04:13 AM
Ok, this is the scenario
Alcatel phone ext. 397 -----------> ALCATELPBX <--------- S0 ext. 136 ---------> CME <------------IP Phone
Then, when i dial 136 from 397 the IP Phone rings, but it seems like the comunication is only i one direcction because i hang up but alcatel extension still dial and i dont hear anything.
I think thats is a mismatch with the ISDN protocol in both sides but i dont know how can i trace it.
03-10-2010 03:18 AM
Take "debug isdn q931" and "term mon" when doing the above.
Post it here, do not enable other debugs, do not use attachments.
03-12-2010 04:38 AM
The debug.
Mar 12 12:41:41.855: ISDN BR0/2/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Mar 12 12:41:45.227: ISDN BR0/2/0 Q931: RX <- SETUP pd = 8 callref = 0x05
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Exclusive, B1
Calling Party Number i = 0x0980, '397'
Plan:Private, Type:Unknown
Called Party Number i = 0x81, '136'
Plan:ISDN, Type:Unknown
High Layer Compat i = 0x9181
User-User i = 0x04
