Need some more EEM help
Mar 4th, 2010
Here's what I'm trying to accomplish:
  1. When both g0/1/0 AND g0/1/1 go down, shut down p0/0/0.
  2. When either g0/1/0 OR g0/1/1 comes back up, wait 5 mins and if either is still up, bring up p0/0/0.
  3. While waiting, if the link that is up goes down, reset the countdown timer.
Previously Joe Marcus Clarke helped solve a similar scenario (see attached) but this takes it a little further. I want to modify that script to accomodate this new scenario.
Would appreciate any assistance.
Joe Clarke Thu, 03/04/2010 - 13:01
What version of IOS do you have?  Your new scenario may not be doable with applets.
rpeasah Thu, 03/04/2010 - 18:58
Here's what I'm running:
asr1000rp2-adventerprisek9.02.06.00.122-33.XNF.bin
Joe Clarke Thu, 03/04/2010 - 19:29
Does this device support the command "show event manager version"?  If so, post the output.
Joe Clarke Fri, 03/05/2010 - 11:49
This one Tcl policy replaces your two existing applet policies.  Before you can register it, though, you need to set a few EEM environment variables:
# pc_intf      : Name of the port channel interface to control.
# pc_member_1  : Name of first interface to watch.
# pc_member_2  : Name of second interface to watch.
# pc_up_timer  : Value in seconds to wait before the port channel is brought
#                back up when a member interface comes back up.
For example:
event manager environment pc_intf P0/0/0
event manager environment pc_member_1 GigabitEthernet0/1/0
event manager environment pc_member_2 GigabitEthernet0/1/1
event manager environment pc_up_timer 300
Then you can register the EEM Tcl policy.
