Cannot dial a specific number
Mar 4th, 2010
I have an issue in dialing one specific number and cannot workout what is stopping it.
When dialing the number digit by digit and then pressing # the message: your call cannot be completed as dialed is played.
If the number is entered in full and then dialed it shows that the call is connected on the phone, but there is no sound heard.
The CUCM is: System Ver: 6.1.3.1000-16
I am using a H323 Gateway.
I have created a specific route pattern to match this number exactly. That pattern has been put into Partition and associated with the correct CSS.
On the H323 Gateway I have created a specific Dial-peer to match this 10 digit number:
dial-peer voice 181 pots
corlist outgoing UK-National-Calls
description UK National Calling Nuttal
translation-profile outgoing Outbound_Trans
destination-pattern 90127655555
progress_ind alert enable 8
port 0/0/0:15
forward-digits 10
Below is the output of a Debug isdn q931:
Mar  4 10:44:02.673: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 02055543666
Mar  4 10:44:02.677: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x06D4 callID = 0x85D7 switch = primary-net5 interface = User
Mar  4 10:44:02.677: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x06D4
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98385
                Exclusive, Channel 5
        Display i = 'Richard Dimond (CHI)'
        Calling Party Numbersh i = 0x0081, '02055543666'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '0127655555'
Mar  4 10:44:02.877: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0x86D4
        Progress Ind i = 0x8288 - In-band info or appropriate now available
Mar  4 10:44:03.289: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x86D4
Mar  4 10:44:03.749: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x86D4
Mar  4 10:44:12.069: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x86D4
Mar  4 10:44:12.073: %ISDN-6-CONNECT: Interface Serial0/0/0:4 is now connected to 0127655555 N/A
Mar  4 10:44:12.073: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x06D4
Mar  4 10:44:18.073: %ISDN-6-CONNECT: Interface Serial0/0/0:4 is now connected to 0127655555 N/A
Mar  4 10:44:22.341: %ISDN-6-DISCONNECT: Interface Serial0/0/0:4  disconnected from 0127655555 , call lasted 10 seconds
Mar  4 10:44:22.341: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x06D4
        Cause i = 0x8090 - Normal call clearing
Would anyone have any suggestions of what I am missing?
All other calls are working fine and the number I am calling is correct.
g1smdvoip Fri, 12/02/2011 - 04:09
Some numbers within the UK 01276 area code have 9 digits after the 0, while others have 10 digits after the 0.
That part looks OK, as long as your called number is one of the shorter ones.
