how to edit SLM2008 switch.cfg?
Mar 4th, 2010
I want have a default switch.cfg and I want just modify  the IP address before import.
It is possible to edit the  switch.cfg?
I try with a text editor, but file may have binary  parts.
alissitz Fri, 03/05/2010 - 20:18
Thanks for posting this. Humm .. a bummer the file formats are not the same across all the platforms ...
Yes, I see what you mean.
I do not see a way either, and my searches have not uncovered anything.
Sorry I am not as much help to you as I would have liked to be, perhaps another on this community will have an answer.
Kindest regards,
