Config job failing
Mar 4th, 2010
I have periodic polling and peridoic colletion jobs scheduled to run everyday at 2:30 and
14:30. These jobs are in pending for more than 72 hours and I didn't see a new job started
since. Please advise
LMS3.2 on Solaris 10
Joe Clarke Thu, 03/04/2010 - 13:03
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
It sounds like ConfigMgmtServer may have locked up.  Get the PID from the output of "pdshow ConfigMgmtServer", then run "kill -QUIT PID".  Then post the daemons.log file.
nawas Fri, 03/05/2010 - 06:44
I ran the kill command and here is the daemons.log file.
Joe Clarke Fri, 03/05/2010 - 09:16
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Nothing was attached.
Joe Clarke Fri, 03/05/2010 - 09:22
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yeah, there are a bunch of threads stcuk in a loop.  This appears to be related to a problem performing terminal setup on WLC devices.  At this point, you will need to restart ConfigMgmtServer to resume config archive operations.  However, I would be curious to know if you can replicate this problem, and if so, with what WLCs (i.e. model and code version).
To restart ConfigMgmtServer, run the following two commands:
pdterm ConfigMgmtServer
pdexec ConfigMgmtServer
nawas Fri, 03/05/2010 - 09:27
WLC? I didnt' mentioned WLC in my thread. You are asked me stop/stop the ConfigMgmtServer which I just did and rerun the job and keep you posted. As a side not, I did stop/start the daemon before I started the thread and jobs were still stuck or failed.
Joe Clarke Fri, 03/05/2010 - 09:55
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I know you didn't mention WLC, but those are the devices that are locking up ConfigMgmtServer.  If you're doing a config collection for all devices in RME, then those jobs will probably continue to lock up until the WLC problems can be understood.  That is why I requested info on your WLC types and software.
nawas Fri, 03/05/2010 - 10:07
Agree. WLCs were recently added in the RME. Does RME support WLC for config Archive?
Anyway, you asked for the WLC model and version I'm using
AIR-WLC4402-50-K9
AIR-WLC4402-25-K9
AIR-WLC2125-K9
and all are runing version  6.0.188.0
Joe Clarke Fri, 03/05/2010 - 11:18
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Since you already have a TAC service request open, I suggest this problem be worked there to avoid duplication of effort.  You can post the resolution when the service request is closed.
